Hello,
i am building a 350z drift missile with a florida imported Aristo 2jz GTE VVTI
My partner and I are trying to make it as "budget friendly" as possible while still retaining reliability and decent performance. We have a build list of new parts such as top mount manifold, turbo, gaskets, studs, oil pump, water pump etc etc.
So here is my question.... while the engine is out, we were planning on doing all the rotating assembly bearings and we were wondering If it would make sense that we pull the pistons out, clean it up, then replace all rings, then finally hone the cylinder bores with a honing pad/stone ourselves
I know that you shouldnt trouble the rings and bores if you are making good compression but if the engine is out... wouldnt it be a good idea? Is this too risky? i have seen a few people who have just got a hone and new rings and reused the stock rods and pistons but i would like to know if honing is something you can do your self and still achieve good results.
https://www.sau.com.au/forums/topic/481218-engine-rebuild-question/
EDIT: look i know that you  "CAN" do it your self and there is a few videos on youtube who show them selves at home with a drill and what not but i want to know if what they are doing is wrong and if they are just a set of bone heads. so yeah thats my question... lol ?
Yes, you can. The main issue is the drill speed too fast and it cuts too shallow a cross pattern. Something slow, eg cordless drill on low speed and a fast up/down motion, will work fine. Does't need long to work. Yes you should replace with new rings while out, and from there yes you should re-hone.
  • Like 1
If you pull it to pieces and the cylinder bores don't show much wear and the rings look good why touch that at all unless you are paying to do it right?
Actually, This ^.
Just because you pull it apart doesn't mean you automatically do anything. The only thing you have to do is carefully inspect and measure everything. If the bores are round and especially if there is no nasty lip at the top and especially especially if the hone marks are still visible, then doing anything to the bores is unjustified. You always assess what you have before deciding what you're going to do to it.
And then forget what you decided and mash the go button on that Nitto stroker kit.
  • Haha 1
2 hours ago, Unzipped Composites said:
Humorous reference to the natural tendency to completely blow the budget despite the intentions going into the build.
i was attempting my own humorous reference to accidentally purchasing hks h-beams (and a billet crank, which a workshop “lost”)
hey, each to their own...but, if i'd picked up a 2nd hand unknown engine, I had it apart, and was rebuilding it to ensure it was fresh and ready to last for me, there's no way i'd be sticking with the rings that were in it; i'd replace them along with bearings, water pump, timing belt, anything else that might " look fine". A set of rings is like 200 bucks, a hone does effectively nothing to the bore size, and pulling out and dismantling the engine is one Fkton of work, as anyone that's ever done it knows, so replace them while it's all apart, if budget isn't the utmost concern.
  • Thanks 1
On 25/09/2020 at 6:57 PM, Duncan said:
Are you putting a 2jz in a 350z for a cheap project?
4th time this week, thanks skid factory.
Adam lz has put more Jz engines into cars then the skid Factory
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
