Hello,
i am building a 350z drift missile with a florida imported Aristo 2jz GTE VVTI
My partner and I are trying to make it as "budget friendly" as possible while still retaining reliability and decent performance. We have a build list of new parts such as top mount manifold, turbo, gaskets, studs, oil pump, water pump etc etc.
So here is my question.... while the engine is out, we were planning on doing all the rotating assembly bearings and we were wondering If it would make sense that we pull the pistons out, clean it up, then replace all rings, then finally hone the cylinder bores with a honing pad/stone ourselves
I know that you shouldnt trouble the rings and bores if you are making good compression but if the engine is out... wouldnt it be a good idea? Is this too risky? i have seen a few people who have just got a hone and new rings and reused the stock rods and pistons but i would like to know if honing is something you can do your self and still achieve good results.
https://www.sau.com.au/forums/topic/481218-engine-rebuild-question/
EDIT: look i know that you  "CAN" do it your self and there is a few videos on youtube who show them selves at home with a drill and what not but i want to know if what they are doing is wrong and if they are just a set of bone heads. so yeah thats my question... lol ?
Yes, you can. The main issue is the drill speed too fast and it cuts too shallow a cross pattern. Something slow, eg cordless drill on low speed and a fast up/down motion, will work fine. Does't need long to work. Yes you should replace with new rings while out, and from there yes you should re-hone.
  • Like 1
If you pull it to pieces and the cylinder bores don't show much wear and the rings look good why touch that at all unless you are paying to do it right?
Actually, This ^.
Just because you pull it apart doesn't mean you automatically do anything. The only thing you have to do is carefully inspect and measure everything. If the bores are round and especially if there is no nasty lip at the top and especially especially if the hone marks are still visible, then doing anything to the bores is unjustified. You always assess what you have before deciding what you're going to do to it.
And then forget what you decided and mash the go button on that Nitto stroker kit.
  • Haha 1
2 hours ago, Unzipped Composites said:
Humorous reference to the natural tendency to completely blow the budget despite the intentions going into the build.
i was attempting my own humorous reference to accidentally purchasing hks h-beams (and a billet crank, which a workshop “lost”)
hey, each to their own...but, if i'd picked up a 2nd hand unknown engine, I had it apart, and was rebuilding it to ensure it was fresh and ready to last for me, there's no way i'd be sticking with the rings that were in it; i'd replace them along with bearings, water pump, timing belt, anything else that might " look fine". A set of rings is like 200 bucks, a hone does effectively nothing to the bore size, and pulling out and dismantling the engine is one Fkton of work, as anyone that's ever done it knows, so replace them while it's all apart, if budget isn't the utmost concern.
  • Thanks 1
On 25/09/2020 at 6:57 PM, Duncan said:
Are you putting a 2jz in a 350z for a cheap project?
4th time this week, thanks skid factory.
Adam lz has put more Jz engines into cars then the skid Factory
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
    • Hi, Got the membership renewal email but haven't acted yet.  I need to change my address first. So if somebody can email me so I can change it that would be good.
    • Bit of a similar question, apprently with epoxy primer you can just sand the panel to 240 grit then apply it and put body filler on top. So does that basically mean you almost never have to go to bare metal for simple dents?
    • Good to hear. Hopefully you're happy enough not to notice when driving and just enjoy yourself.
    • I mean, most of us just love cars. Doesnt necessarily have to be a skyline.
