Hello, bad news ?
I installed injectors (1000cc top feed) 2-3 weeks ago, All seemed good.
Untill today I did a boost leak test and the injector oring bosses have pushed out....wtf
Before I go and pull it all apart, what do you guys think I've done wrong for this to happen.
Thanks ?
Edited by dyl33
https://www.sau.com.au/forums/topic/481235-injector-o-ring-bosses-pushed-out/
It looks like the fact it could move up the rail is too high.
Need to reduce the length of the spacers, assuming there are spacers.
How much pressure did you apply for the leak test?
@Ben C34 after further inspection i believe thiere is a problem. See pic.20200927_120017.jpg.57000c0be448a6322d8ee8548359a439.jpg
There's a decent gap at the top which would allow it to move up, i think this is the problem. Or am i missing a spacer or somthing?
The injector kit only works with 3/4 height top feed.
I was sold the kit by Kudos motorsport with ev14 1/2 height injectors with height adaptors (short, 14mm)
So im not sure if I've been given the wrong injectors or is there an issue the the injector o-ring bosses or somthing else.
Thanks robbo, yeah maybe I'll have to if there's no other way. but its strange there's a instruction manual to install this fuel rail kit. States 100% bolt on and mentions nothing about shaving spacers down. ?‍♂️?‍♂️
I'll find out more tomorrow hopefully.
Edited by dyl33
I have the taarks kit and it all bolts in nicely - my spacers don't look like that though and i use the injectors that came with the kit, bosch 960cc
Thanks @hardsteppa yeah I reckon Kudos has made a mistake. It should work 100%. Are you able to get a pic of you spacers/rail?
Edited by dyl33
also i remember during the install; the bosses pushed in but then some popped back again again like yours is in your pic. Had to push them back in slowly (taarks note this in their instructions) for it to slide in and stay in; not any further issues other than that though.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
