Hi All.
I'm wondering if anyone has recommendations for a good dial gauge kit that they've used on an RB26.
Got to get the gauge located right at the correct spot and angle and a good sturdy base to sit in the valley.
If anybody has done this before I'd much appreciate any recommendations.
https://www.sau.com.au/forums/topic/481258-dial-guage-for-rb26-cam-degreeing/
Just about any non-who-flung-dung brand dial gauge will do. All you need is a steel plate you can bolt down to a coil bracket hole, a mag base and a couple of adjustable arms to mount the dial gauge, and maybe an extension or two to screw onto the probe.
viz
https://adelaidetools.com.au/hand-tools/engineering-tools/moore-wright-0-10mm-dial-indicator-mw400-05-14418.html
https://adelaidetools.com.au/hand-tools/engineering-tools/moore-wright-magnetic-dial-indicator-stand-mw-475-01.html
Might have to look elsewhere for extensions.
Would expect you'd be looking for something beyond 10mm -  a 12mm or 1/2" DI, if this is a moderate performance application.
Chinese probably can't stuff up something as simple as this you'd hope either - and if you go to the usual suspects like H&F, probably the most likely country of origin you'll find! One thing I will say, get an analogue one, digital are horrible things!
