I WTB raised center caps for LMGT4s but they are discontinued.
Am I SOL getting anything else from Rays range that will happen to fit?
They are the press-in rubber ring type, not the clip type. nengun still sell the flat ones. I fancy the hub ones.
If anyone has hub ones in bronze, I'll happily swap for flat, and pay $$s.
Edited by phelbas
https://www.sau.com.au/forums/topic/481277-who-is-an-lmgt4-center-cap-expert/
It's been a long time since I chased some up for mine (I was after the flats though) but I thought they were interchangeable with te37 from memory.
I'd just be keeping an eye on yahoo auctions for them, have you asked other importers as well in case they can still source? Import Monster, Jesse Streeter, etc.
Not sure if it will help but I've got the part numbers for them.
Standard type with Rays logo (depth 25mm): 40315-RN850-BR (BR =Bronze, swap 'BR' for 'S' or 'BK' to get silver or black)
I know nothing about LM 2/3/4 center caps ! ! ! ( search search search ) . . . . .
But if you get stuck the and you still want to go with that style of cap then the alloy outer body could easily be spun up on a lathe.
The center section looks like an insert and could be molded up in various plastics or resins to suit
thanks
been searching my head off. There is much confusion over diameters not helped by two styles, o-ring type and clip type. If te37 are the same then that helps. I sent an email to rays wheels to see if I can get an answer.
On facebook marketplace I found a NOS high set but black, not bronze. I guess I could get those powder coated if the correct color never appear.
the nengun bronze flat caps I have are an annoyingly slightly incorrect color match for my bronze wheels just to make things more irritating.
From my understanding the clip type where only sold in the States as they were dealer option on z33's.
My previous set of LMGT4's were bronze & I found the same thing with the centre caps, the 2 that came on my wheels when purchased were a different finish but the new set of 4 I got matched correctly.
Same issue with my silver 19's, caps available in the standard silver anodised finish that matches the spokes and in the 'diamond finish' to match the machined section in the centre of the wheel.
  • 3 weeks later...
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
