Hey Guys,
I did an RB20DET swap from an R32 into my Cefiro. I've also converted it from auto to manual.  The problem I'm having is that when I plug the speedo sensor cable into the back of the gauge cluster, it kills the car when I hit about 20km.  If I disconnect the speedo cable, it runs perfectly, but I can't see how fast I'm going.
All of the other connectors work fine on the cluster, such as lighting, fuel gauge, temperature.  It's only when I connect the speedo cable in.  Before, when I was running the RB20E, it worked perfectly fine.
Do I have something not connected right?
More information required.
Was original Cefiro auto speedo sender electronic?
What speedo sender (from what origin car, gearbox, etc) is in the manual trans?
What does the speedo head in the Cefiro want as an input? Cable drive or electronic? (and I realise that what you have between the gearbox and dash must work, because you say when you plug it in you can see the speedo work, but I'm just trying to get the full picture).
What does your wiring diagram say about the signal line from the dash to the ECU? You do realise that the speed signal that the ECU watches is created at the speedo head, right? Whatever the speed signal into the speedo head from the sender is (and it could be mechanical drive, like in an R32, or it could be an AC voltage from an electronic sender like in an R33) then the speedo head translates that into a square PWM signal for the ECU. There could be a difference in wiring at the ECU between the original RB20E plug and the RB20DET. You could be putting the speed signal into the wrong place on the ECU.
The RB20DET ECU can and will run without a speed signal. Just some functionality doesn't work properly as a result. But this used to be the stupid bogan way of beating the 180k speed cut. So we know that the ECU doesn't absolutely need a working speed signal to run the engine and drive at more than 20k. But putting the speed signal into the wrong input on the ECU could be quite a bad thing to do.
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
