I am in the process of refreshing everything under the dash - heater core, ducting, blower motor, etc. And I made a discovery.
It appears someone has modded the existing Air Con box to fit two filter elements. Only problem is, they are nothing like the ones Nissan actually used later on in the Stagea. I have also verified that the air con box is period correct for the car.
I have been scouring the internet (and this site) trying to find information on their replacement, but NOTHING. There are no distinguishing markings on the filters.
The bottom one was secured with a screw in the bottom, and there was a metal clip holding the two together. The bottom one is removed first, then the top slides downwards and out.
The elements were DISGUSTING! I tried to clean them, and they fell apart. Still... nothing is probably safer than the festy things that were there.
Any info is greatly appreciated... I don't even know where to begin. But I would like to replace them.
I highly doubt Nissan would have made custom cabin filter just for the C34 wagon.
Quick look on Australian Ryco site: https://www.rycofilters.com.au/Search/SearchResult?make=NISSAN&model=STAGEA&year=null&liter=
RCA318P
I'm sure you can find an equivalent over in Germany.
yeah, so if you throw in the factory-spec filters you should be good to go? Besides the damage to the box...
Unless the box isn't designed for a filter... I guess you can measure and see what fits, then smash it in there like the previous person haha
On 10/13/2020 at 8:59 AM, GTSBoy said:
I'm not sure he meant "custom" as in Nissan did it. I think he means "custom" as in "bodged into the heater housing by a butcher". Custom as in "jammed filters meant for something else into a hole hacked into the car". Etc.
This is exactly what I mean! Thanks. The box was cut. And looking at all the pics I can find on the S2 filters, these are not the same. The outside of the filter is the shape of the edge of the A/C box. It's weird
Thanks for replies, but these are NOTHING like the S2 (or equivalent) filters. I wish it was that easy. These are probably some one-off thing that a previous owner did.
Below are the S2 (and/or equivalent) and the one's I pulled out of my car.
    • The easiest option might be to just spray a bunch of fish oil in there.  At least that way you can feel like you've done something while you continue to ignore it
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
