We've been running an RB25/30 R33 track car for 3-4 years, putting out around 300 RWKW. All was good, until it wasn't - a funny noise & a locked engine, and we found part of a rod on the track. The engine was built with stock rods & pistons.
Haven't pulled the motor out yet, and can't even see where the hole is, but it's clearly terminal. We've sourced another RB30 block, but couldn't see until we started stripping it that it doesn't have the flat surface on the front for the relocated tensioner. Apparenty very early RB30's were like this.
A bit of research shows that Platinum Racing Products sell a converter - it looks like a shaped plate that somehow attached to the front of the block to allow the tensioner to be fitted. I can't find anyone who's used one, nor much other info about them. Does anyone here know anything about this? The plate is https://platinumracingproducts.com/products/rb30-s1-block-converter
Not sure whether to continue with this block, or ditch it and find another one. It does have the turbo oil & water ports on th eexhaut side. The new build will include forged rods & pistons, to try and avoid a repeat problem.
11 hours ago, GTSBoy said:
Would it not be possible to simply put the engine into a milling machine and duplicate the machined surface?
No, this area on the early blocks needs to have material added, not removed:
8 hours ago, Rusty Nuts said:
Page 7 of this PDF.
I can't see anything on page 7 that helps me - can you expand? To be clear, my problem is mounting the idler/tensioner where the top photo on page 7 shows "RB25 Idler". The pic above shows the same location without the idler. On later blocks this area is filled to the same level as the area on the left hand side of the pic.
Personally I would get a the correct block rather than use the adaptor. You should only use adaptors if you really have to, and considering there are still blocks around, and you haven’t done any work to this one , makes sense to change now.
It'll be fine.  Get a small section milled out of the block and then fit a spacer in that milled section to achieve the desired height for the pulley to mount to. Mine is done this way. Can't remember if I've got photos anywhere....
1 hour ago, Shoota_77 said:
Here we go, not a great photo but hopefully you can get the idea.
Thanks for that - massive help. I assume the spacer is just sitting between the block & idler - not welded / JB welded or anything?
Yeah - I'm on the fence at the moment. There is a suggestion that the S1 block is somehow stronger, and I've got it. OTOH it was cheap, and maybe the newer block is the better option. I was hoping to find someone who has used the PRP plate - I can always ask them but will they tell me if it's not a good solution?
Yes mate, its just an alloy spacer.
On 10/19/2020 at 10:44 AM, Rusty Nuts said:
Or even easier
Thanks - lots of options there. I had considered the last option, and decided that if it was that easy everyone would be doing it, so didn't think anymore about it.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
