Rob's S Chassis track cars. Now with more s15 and less 180sx
robbo_rb180
 Share
I find building an exhaust a really satisfying job!
Looks nice!
Did you consider using an oval pipe to get the same cross sectional area but keep it above the chassis rail?
@robbo_rb180 do you tune your cars yourself or do you send them to someone?
If you do it yourself, do you hire a dyno, or tune it after logging it at the track?
Meaning like touch ups when you tweak or modify something a bit :)
I've looked at some oval stuff but still deciding what material to use for the back half to the muffler.
Yeah I do all my own stuff with ecu setup and have it sorted before generally paying someone (my old work) to do base runs and a few power runs then I'll do anything else myself at track or after review data. It's hard to find  a dyno owner these days that will hire out to random.
  • Like 1
I didn't realise you used to work at a place that does tuning!
I know while I'm putting the Subaru back together it'll need a remap, but I'm pondering how easy it'd be to do logging at a track day.
I've got an Innovative LM-1, and am pondering if I get a new O2 for it, or what a decent Wideband (standalone) sensor and controller is worth that I can log (And either ECUFlash or ECUEdit might support).
I was searching for hiring a dyno for DIY tuning but looks like only 2WD dynos can be hired at the moment and I need 4WD :(
  • 1 month later...
Rob,
Updates on build mate?
Do I need to drive round your way and prod you with a stick, or is work just too busy at the moment? I'm happy to write you a resignation letter if work is getting in the way of building your own car :P
1 hour ago, MBS206 said:
Rob,
I got shiny stuff (radiator and intercooler) from pwr about 5 weeks ago. Did all new bolts and orings on inlet manifold, bolted it on and started planning engine bay fuel lines.
Test fitted 350z dbw pedal, need to make a bracket to sit better with pedals.
Ordered a nismo diff through streeter and waiting on it arrive.
Hardly have any time to work on it as work is crazy busy and needs a fair bit of commitment to do well and its  proved with past few rounds with a few 10 tops and a win in Tasmania.
I have also stopped and reassessed what I want to do with the car too. I was trying to get it to fit wtac clubsprint rules as only needs a few bits changed that are bolt on but not worth the effort so just having a good think about it. Working with some very experienced race car builders and engineers has definitely changed the way I want to put it together as well.
Some pics of test fitting rad and cooler
Messenger_creation_3ac566a1-3e67-4315-b1d9-5d65de03d0ca.thumb.jpeg.43db93b02e3a551f78472d4ee63df023.jpeg
Messenger_creation_b0bffd39-8e87-49bc-9b28-d12693e2f3c5.thumb.jpeg.073fa1adc0af229bdec882e1147d76e1.jpeg
Work things
And also fresh turf to finish my backyard
  • Like 6
Diff arrived from Japan last week.
Nismo gt pro 1.5way for gtr. Still deciding whether to use 4.11 or 3.9 gears before installing.
Spent some time yesterday going over what's needed to finish engine bay fuel lines. Got a list so will order soon. Played with radiator placement and decided on stock location with bottom spaced a bit for a small amount of angle. So ordered standard mounts and rubbers. Reason for this is the 180sx was a pain to work on any of the coolers and was also going to take longer to fabricate mounts.
Today made a bracket to mount the dbw throttle pedal. Factory location wasn't great to work with the pedal box. Luckily there's a rail that pedal box mounts too so did some measuring, drew up a design and got stuck in.
It's made of 3mm aluminium and has a lot of strength just need some bolts, washers and nuts to finish up.
If I get time tomorrow I'll pull the front bar and lights to start intercooler mounting, it will be flipped under the rad support which will require some trimming.
  • Like 4
 Share
    • Yes sir, that was me. Fake ARP's are also a thing over here in Canada and we only order from reputable dealers. It's sad that even simple things like bolts and hoses are now also being copied... anything to make a dollar.  Story time. Like all cheap crap from China, it's even an issue with firearms. Roughly 15 years ago, I purchased a new cheap Norinco 12g shotgun. First time out in the bush with it, while firing, bolt assembly didn't lock and it fired out of battery. The receiver also being cheap steel, basically exploded in my face. I was lucky to be wearing eye protection. Long story short, don't buy Chinese junk. Also Norinco being state run and their only military arms producer, if ever they do try and take over a country, don't worry about it lol.
    • Installed  Nismo coppermix twin competition spec last year in my bnr32 with pull trans with Oem slave cylinder. The point at where the clutch disengages/enages is right at the top of the clutch pedal, meaning I barely have to push the pedal down for the clutch to be disengaged.  You guys that have the same combo are you experiencing this high pedal bite point??   Secondly I’d like to have the disengagement point lower meaning I have to push the pedal more(further not effort)for it to be disengaged.  I’m thinking to use a Nismo big operating cylinder(bigger bore at 13/16 vs Oem 3/4) which will require more pedal stroke to get the equivalent movement at the clutch fork. But I see Nismo web site says not to mix these 2 as the Nismo big operating cylinder doesn’t have enough stroke to disengage??? Any folks run both the coppermix twin pull with Nismo cylinder??    Thanks in advance for the replies but prefer only guys with pull clutches to respond. thanks
    • Any chance u could let us know where your based ?
    • That’s a great deal and I would jump on it if you were closer. Melbourne is a bit of a hike for me though unfortunately
