So it seems i've unfortunately purchased an absolute sh*t show. I'm hoping someone can help me with my issue or shed some useful advice. Car is fitted with aftermarket alarm (not 100% sure that's the issue). Car also has a brand new wiringspecialties engine loom for an RB20det.
I've had loads of wiring issues with my car since the start, there's a turbo timer, boost controller gauges etc all powered off what was the radio.
Currently, my indicators, brake and dash lights don't work, however my headlights do. I've now also got an issue with my starter signal only being 6volts instead of the full 12, so not getting crank either.
What also might not of helped, is my mate has put the battery in the wrong way round at one stage, which i think also possibly caused some of these issues.
I have also been offered an interior loom from an automatic, would the interior side of this be the same as a manual?
I know there's a lot of issues, but i appreciate any help or at least a starting point to check. I've checked the fuses and all looks ok. Fuel pump still primes as well to add to the confusion
https://www.sau.com.au/forums/topic/481306-r32-skyline-help/
Whether the interior loom is the same or not (probably is), that is unlikely to resolve the issue.
Best suggestion might be to take it to an auto electrician and get them to sort it, but will cost somewhere between "a bit" and "heaps" because there will be lots of tracing involved.
Alternatively if you have the time and patience to sort through it yourself, you need to get the R32 GTR workshop manual which includes the RB20 wiring diagrams and work through everything from the power supply circuits. The battery connection issue will have blown at least one fuse and sounds like it has also caused some issue with your key barrel or it's wiring (or possibly ECU fried, depending where you detected 6v)
  • Like 1
  • 3 weeks later...
6 hours ago, ryand96 said:
Right, so I've sorted the P/n bypass, and have now got spark and a crank, fuel feeds to the rails.
Only thing I'm not getting is the injectors fueling. Any ideas of what to look at for this?
When spinning the cas can hear the injectors click/buzz
Check you have the feed and return to the rail the correct way around
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
