Hello All,
I have a single turbo rb26 240z (432z tribute car) that I'm going to rebuild to my planned second phase which consist of forged internals, HKS Vcam Step 2 , and oil control. My Question is my valve covers were modified by engine swap bracket company to clear the hood release bracket, so they now sit directly above the oem mesh screens, is there anything wrong with this setup? With New V-cam valve cover I would have to mod again, so holding off for now. Will upgrade to High Octane baffles. Will be a track car mainly so oil control is a big reason for the build
https://www.sau.com.au/forums/topic/481308-240z-rb26-oil-cam-cover-control-qs/
Isn't the point of the breather being all the way at the end of the baffling/mesh path to try and keep as much oil out of the lines as possible?
If this is a track build first and foremost just go dry sump and none of this matters. Cap off the breathers and let the scavenge pumps deal with it. It will keep you from ventilating the block.
14 hours ago, brian_s30z said:
Dry sump is an option, but I’ve already invested in a 7litre sump, spline drive and oil pump. Then I need to restore and paint the car so don’t really want to spend more.
If that's the case then my advice is to run tires that are not particularly grippy to avoid pushing the limits. Ventus RS4s are supposedly good for this, a durable track tire that has relatively low grip.
Moving the breather position forward a little may not matter much, but if it does make enough of a difference you may need to drain the catch can back to sump. On a track car this isn't a big deal, oil temps are high enough that water/fuel won't accumulate. I would also add a line just before the turbo after the catch can to try and ensure that crankcase pressure is at least atmospheric. You have to make sure that the air coming out of the catch can is as clean as you can get it though.
  • Like 1
More realistically, dealing with the oil supply and drain side of the equation is going to be more important than whether the cam vents are a little compromised compared to normal RB26 covers. I mean, how are these any worse now than standard RB25 covers, right?
So, read the last 100 pages of the oil control thread, do the right amount of supply restriction, add in some big sump vents to the catch can and make the best of it.
  • Like 1
Well one would assume that they probably haven't modified the baffle positions to suit the new breather locations though, so they may effectively have half the baffles. On a 25 the baffles are still positioned accordingly.
Whether that actually makes much difference or not on a track car with inherent oil control problems? Probably not so much.
  • Like 1
Thank you. thanks for the suggestions. Don't plan on reaching limit or be competitive. Block and Head will be machined for ~+1mm on oil returns.
I think I'm going to move the breather location back to stock, just half a -10 hole size forward on intake cover. I checked my V-cam cover and the "POWER" logo sits right where my welded AN is.
"I would also add a line just before the turbo after the catch can to try and ensure that crankcase pressure is at least atmospheric." not sure how to add a line here?
Your catch can has two little breather filters on it, what you probably want to do is run those lines just after the air filter on the turbo but before the compressor inlet. Just make sure your catch can is actually filtering out all of the oil.
  • 5 weeks later...
There lies a question.  What does the catch can have inside by way of baffles/filters/flow restrictors etc etc to stop the puked oil getting out the breathers and just as importantly the accumulated oil sloshing around.
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
    • Just report the OP (via the 3 dots menu at the top right of post) and request deletion.
    • And boosters can be rebuilt by the same sort of brake shops that will rebuild a brake booster.
