Hey guys,
My 33 GTR is making a weird rattling noise after driving it for a while. It tends to go away after you shut the car off and start it back up again, it sounds like something is loose and rattling around somewhere on the passenger side under the intake piping for the turbos. It doesn't get louder the more you rev the car, if anything it goes away. I'm going to drain the oil here shortly and have a look for any metal shavings.
Turbos are stock to my knowledge, they were going to get changed out this winter as well as the basic oil restrictor mods, etc..I just got the car with intention of doing a restoration over the next few years.
What are your thoughts? Is this going to need a rebuild right away?
https://www.sau.com.au/forums/topic/481330-rb26-rattle-spun-bearing/
Don't often get to say this about an rb, but that is definitely not a spun bearing.
It will be some thin gauge steel rattling against something else. Maybe a loose turbo heat shield, the air/water lines or some other random bracket not attached properly. Not a big deal but you should get it sorted so whatever isn't meant to be rattling doesn't break.
BTW I'm sure you're concerned....but 2 hours in the middle of the night was pretty early to bump the question!
Sorry about that, I was definitely nervous and anxious; I tend to get that way when something could be horrible. I figured it wasn't a bearing either because it doesn't get louder or worse the more I rev it. On cold start it doesn't happen (from what I can hear), i'm going to have a deep dive next weekend and see if I can find the issue.
Thanks for the reply Duncan!! I really appreciate it.
Yeah apart from the quite different tone, rod big end bearings (most common failure) are noisier when cold (thicker oil, higher clearances) and noiser when you rev it (rod moves faster, failed bearing lets it move more), and the speed of the knock increases with revs too. It is quite a distinctive "gnomes with hammers inside your engine" noise
  • Haha 1
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
