I have a second blank key, and a transponder chip that came out of a japan installed remote start device that fooled the stock immobilizer into thinking there is a correct key present.
How do I remove the red part if this is even possible? (before digging at it with a razor blade perhaps should ask)
alternatively, who currently duplicates a key in sydney. I did phone Tom at the sydney locksmith place recommended previously and he suggested I try the chip implant first.
answering my own question here for completeness, the transponder tray if it slides out at all perhaps needs some kind of tool to compress the sides.
Here is a tray and chip I found in my old alarm system - to allow remote start to work. It was contained in a box with relays, a coil round the chip and a booster antenna.
A red color means non crypto transponder chip however cloning them away from the car is a black art. A “prepared” but blank chip is needed, the spare key I purchased ages ago turned out not to have a chip in it at all!
r34 of the era is NATS2 (NATS1 did not use a transponder chip) obviously a new key can be programmed by Nissan Consult but some of the right key programming tools may also work for cloning. I think in locksmith terms the transponder type is ID41
The way I dug the tray out was by damaging the visible part and pulling with needle nose pliers.
I still have no idea how to remove the tray correctly.
anyway because my Japan installed alarm had a spare chip in it, I am good. The locksmith (mistermint) wanted to charge $90 to code a blank chip but his device did not give him a clone option using the working key.
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
    • Hi, Got the membership renewal email but haven't acted yet.  I need to change my address first. So if somebody can email me so I can change it that would be good.
    • Bit of a similar question, apprently with epoxy primer you can just sand the panel to 240 grit then apply it and put body filler on top. So does that basically mean you almost never have to go to bare metal for simple dents?
    • Good to hear. Hopefully you're happy enough not to notice when driving and just enjoy yourself.
    • I mean, most of us just love cars. Doesnt necessarily have to be a skyline.
