4 hours ago, Nollaig said:
I dont know the limits of a regrind on a crank.
I've had cranks reground. 20 thou (0.5mm) max regrind as you're limited on the bearing sizes available for an RB. Steps are standard, 1, 10 and 20 thou undersize. Obviously it would be crack tested first before any work as mentioned. Looking at it, it might not be doable and if it is it would be definitely a 20 thou regrind for sure to be at all useable.
That crank is also not "slightly" pitted. Looks like it's been left outside in the rain for a year.
