Hello Guys , i am just after some help and advise :  I decided to do the timing on a V35 2001 skyline VQ25DD although there is a lot of info on others VQ not much available for the older series like this one . while removing the camshaft bolt accidentally my cams were rotated and lost the original position and now i am in a big dilema whether the lobs are in the correct position or not  I have set the chain and tensioners and guides  and cylinder 1 at TDC confirming with old screw driver method,I have rotated the engine manually and it goes freely  , I also noticed that inside the timing case there is a small pimple and the intake sprocket has a dot that i think I should be aligned with that one ? (as per photo) while on the bank 2 seems to be aligned  is a fun job but a live or die for me ( i am not a mechanic hope this is clear enough ) thank you
Hey Mate take a look at this on this forum
Looking For Timing Marks V35 Skyline
By MJTru, February 3, 2016 in Naturally Aspirated Performance
Edited by Rusty Nuts
resize
  • 1 month later...
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
