My close associate is in financial hardship and may be seriously considering the sale of his pride and joy.
Beautifully presented R34 GTR, Genuine V-Spec, Nismo blue.
30k, this vehicle stands out from the crowd.
Has some reasonably serious mods, including genuine N1 Turbo's, Top Secret Carbon Fibre Bonnet amd huge rear wing, NISMO LM wheels, HKS fuel rail, rear boot is set up running extensive fuel lines, triple plate clutch, runs a comfortable 1.2 bar, has not tuned it for max output yet, as he is quite conservative, and believes it has more than adequate pwr.
Had 1 run on dyno...310 KW at the wheels - with slight tuning, very capable of 400 plus.
If you are GENUINELY after an exceptionally striaght R 34 GTR, this one is fantastic. IT has NEVER been in an accident, no exceptions to this rule. There is no bog anywhere on this vehicle, and panels line up beautifully.
Pics available on request and will provide more details and pics to those genuinely expressing interest.
Looking at serious offers in excess of $85 K, which is exceptional value for this calibre of vehicle and the dollars invested.
Interested parties, pls send pm, or email interest to me at [email protected].
Vehicle is in Melbourne.
Cheers.
https://www.sau.com.au/forums/topic/48147-eoi-r34-gtr-vspec-nismo-blue/
I agree that with those mods it is worth in excess of 85k. Is there any chance he could put it back to stock for sale at a lower price though? He could probably recover more cash selling the parts seperately.
I think a lot of people looking on the Skyline forums for 2nd hand skylines know alot about pricing and really want to get the best deal, too often skylines are sold on the forums quite cheaply, good for buyer, not the greatest for seller. I hope that the car is sold through the paper and some chump pays more for it.
bump...
Thanks bud...
wasnt this the 34 gtr that pushed 260kw at the autosalon in melbourne earlier this year? I think so. n1s with 400kws ? where ? where? Where can i get a set of those? T78 setup by Race Pace - and im only pushing a tad over 400 at the wheels and thats in shoot out mode. Nice car though, not sure about the claimed power. No offence intended Kitch.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
