Hello, had my car tuned on 98  and E85 (470hp 19psi) and want some advise on spark plugs. I currently have BCPR6ES gapped down to 0.6mm  using splitfire coils. This setup has no issue with missfire at full throttle on both fuels. But low load has abit of missfire on E85 and even more on 98 which I believe is due to the gap size. Can anyone confirm and advise on a better spark plug combination of any?
Cheers
https://www.sau.com.au/forums/topic/481488-rb25-e85-flex-tune-spark-plugs/
At 470hp you shouldn’t be gapping them at all. Could change the plug to R5671A-8. There a ngk race plug that I run, 28psi on 98 with splitfire coils no problems. The plug your using did cause me a misfire up around the 22-25psi but once changed it’s all good.
Do you have a wideband? I wouldn't be surprised if it's a misfire due to a lean condition.
At 1.3bar of boost, 0.6mm gap and Splitfires are a walk in the park. You could run 0.8mm gap and still be fine.
51 minutes ago, burn4005 said:
Denso IK01-24 or NGK R7434-8.
best plugs out there and a lot cheaper than a new set of coils. fine tip iridium.
I've had a set for 2 years in an 780hp rb26 and they're still perfect.
Was curious how much the NGK racing plugs were, I think i may hold off on purchsae
  • Haha 3
They definitely are, but it's really only cost effective bundling with other stuff you order. I run the R7436-8 (53mm old JIS length like bcpr) as it is actually the correct length plug for RB26, not the R7434-8 (50.5mm ISO length like bkr) which is shorter. There's 2.5mm difference in height between them and the old JIS length fits a little better into your coilpacks. Sometimes it's an issue, sometimes not, but the 26 is supposed to have the 53mm length FYI. Fwiw though yeah the R7434/36 is the best plug out there - lowered iridium centre electrode and platinum ground electrode. But at around $50 per unit they'd wanna be...
I've attached the NGK race catalogue for the complete range available, as it's totally separate to the normal NGK site catalogue.
That said, the Op RB25 shouldn't require NGK race plugs though, or a heat range of colder than a 6 or 7 as you don't want be colder than you need to be. Gaps around 0.8mm should be fine too, so maybe 0.6mm is actually a bit small creating a weak spark. Maybe the plugs are just fouled up causing an occasional misfire ?
0.6mm does seems a bit on the small side no ?
NGK_Race_Plugs.pdf
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
