*Updated Date* Lockdown Release Cruise 29th Nov 2020 Belgrave - Gembrook
Join the SAU Victoria team for a social cruise through the Sherbrook Forest.
Initial meeting point will be Upway IGA carpark.
The cruise will head through Belgrave and on to Gembrook via the spectacular Sherbrook Forest.
Where: IGA Upwey, 62-64 Main St, Upwey VIC 3158
Map: https://goo.gl/maps/17R6emXMEuT71ACo7
When: 8:30am Sunday 29th November
Please keep in mind this is an SAU event. To participate you will need to be an existing SAU member or, sign up on the day for 24 hours for a gold coin donation. This is due to our CAMS affiliation.
I will also take this opportunity to remind everyone, this isn't a race, it's not a rally, it's a cruise, at or below the speed limit.
All details will be passed onto relevant authorities if requested.
  • Like 3
Hi all,
I have made a slight boo boo on this one. We (I) have misinterpreted the Covid-19 details and we are not able to run the event on the 22nd. We are now running it on the 29th of November instead. Apologies for the confusion.
But um, the lockdown late was *last* weekend (the 14-15th!)
In any case, this road actually gets better/worth driving on from Gembrook through to Launching Place, then through the Reefton Spur or Mt Donna Buang.
C'mon, get amungst it!
  • Like 1
Ok, so to explain; honestly, i have no idea what we can or cannot do in terms of the lockdown. It's been killing me, i feel like the rules are changing every day. So we are just doing this to be 100% sure we don't cop a giant fine.
Regarding the actual route, you're right, it does get better further on, but I wanted to keep this one small/short as it's my first event that i'm running.
Providing this one goes right, there'll be much bigger, and longer social cruises coming up. :)
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring over comms. Everything critical must still be hard wired.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
