Hey SAU,
I'm looking for any R34 4 door body kits or spoiler options in the aftermarket area. The only options I can seem to find is the JSAI Type R kit for the R34 4 door. Anyone know of any other companies or places that sell good exterior parts for the 4 door. I was thinking of custom work but the cost seem to scare me away. Anyone with any experience with this?
Thanks for any help.
Anything in Australia is a copy of something from Japan.
subscribed for any information myself, lol. Especially if anyone makes a lip kit/side skirt extensions for this thing. I've never found any.
  • 2 months later...
  • 2 years later...
Certain lip kits fit the different series of r34 stock aero ( both gt $ gtt ).
Hasmei do lip kits for the r34 ( you could combine the Jsai type r skirts & rear with a hasmei lip, depending on what stock front bar you have ).
other options are:
orgion labbo - streamline, and uras- d1 spec 2 is the most common one.
however the uras site has a number of kits to suit r34 4 door.
  • Like 1
Shaft Auto Service is a good one, they are a shop in japan that specialise in ER34's (and host the R34 Skyline Festival) - Their 'Type A aero kit' is similar to the Altia kit with a lip kit
https://shaft-auto.shop-pro.jp/
 New Release: Shaft Auto Service R34 4-Door Type-A Aerokit - RHDJapan Blog
They also have a 'Type 3 aero kit' which is similar to the uras D1 spec 2 kit, but flows better
125431040.jpg?cmsp_timestamp=20171119191217
I'm running their sedan trunk spoiler and have been really impressed with the quality, it fits incredibly well for a FRP part
137925949.jpg?cmsp_timestamp=20181207162132
Edited by Old Mates Drift Car
  • Like 1
Final Konnexion also make bodykits for the sedan, but it's more of the same bell bottom style seen on 90's-00's drift cars
https://www.finalkonnexion.co.jp/
This is their 'Falcon' kit
This is their 'Intruder' kit
  • 3 weeks later...
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
    • I just try to entirely stay away from ladder now unless it's something basic maintained by electricians. Even then and to your point, it mostly ends up being blocks I wrote in structured text.  PLC's are slowly going towards C, C++ and C#. I just wish Allen-Bradley would jump on the bandwagon.
    • All of them are missing. You do not get much done with just AND, OR and NOT unfortunately. Ecumaster for example has a text based editor with at least 60+ math and logic instructions.
