My r33 gts has a badly leaking steering rack so I replaced it with one from a gtst which had hicas. The rack bolted up fine but I had to use the lines from the gtst and where the steering shaft spline fits onto the spline from the rack it was much tighter, as if the spline on the rack sat taller but still managed to make it fit.
Before I finish it up, will I run into any problems with this setup?
https://www.sau.com.au/forums/topic/481500-r33-gtst-steering-rack-into-gts/
