29 minutes ago, Super Drager said:
Lol mate ive had it apart and the specs match the real thing. If you don't want one then don't buy one, i'm giving first hand experience since i own one.
I wasn’t having a go, I was asking a genuine question. Wanting to know what you were comparing it to, going from stock turbo to one of these, similar Chinese- Chinese turbo, u have driven the name brand equivalent with exactly the same set up as yours?
what’s the context of what you were comparing to say it works fine.
it’s a turbo sucking air into a motor so yeh it works “fine” but is it making target boost at the right time? Laggier compared to what it should be?
I cant say for my setup as im running mine in a compound setup and rear mounted. However a friends xr6t has gone from a gcg gtx35 to a pulsar and its exactly the same power and spool wise.
On 16/11/2020 at 3:41 PM, khezz said:
Does anyone here use any of their products or know of anyone who does?
There are a few quick reviews on other forums and a few videos on YouTube. So far every comment is positive. All the reviews say they are well machined, balanced on both ends, well assembled turbos. Yet they are less then a 3rd of the price of a precision or a Garrett.
Would be great to hear some first hand experience.
Thank you
They are awesome! Really good quality in machining and materials and perform better than expected. I have a comparison between Garrett GTX3582R Gen1 1 and Pulsar 3566 for what it's worth.
Can we see it?
Just curious, I am assuming this is based on the very scientific eyeball ? I can’t see how you could determine material quality accurately, and I have assumed you haven’t actually measured anything either
Knock offs can work good, everyone knows that. They can also have wildly varying quality and break in unusual ways
  • Like 2
Don't you dare use common sense in this discussion!
Just remember turbos are an afterthought and nobody ever builds a turbo car and anticipates a turbo upgrade...
Your assumptions are third rate. When you assume you make an ass of you and me...
Visual inspection and disassembly of components by a competent tradesperson gives valuable insight.
Axial and radial clearances check out and when monitored are not changing with harsh conditions like 2 bar boost and no BOV. Drilling and tapping housings for anyone with a little experience reveals quite quickly the quality of the material.
If you have ever tightened a compressor cover bolt on a cheap turbo you will know it can be a tentative affair, not so on these.
Threads are perpendicular to machined surfaces etc etc. Fasteners are good. V-band spigots are perfect. They weld perfect. They don't distort. They exceed expectations in quality, reliability and performance.
There a a few minor details that are being improved as with any product.
They are not for everyone. Some people will never be able to accept anything other than name brand and don't have the ability to do their own research and testing. And that's ok.
Hope this helps the OP
  • Like 1
  • Thanks 1
Haha I made an ass of you an me
oh well.
I can also tell how good metal is by the colour of the sparks, but in the end it is a fairly wild guess isn’t it without proper metallurgy?
what are the minor details being improved?they seem quite relevant
oh well.
Material specification is the same as what Garrett use except for 713c Inconel only on the turbines, no Mar-M option at this point.
Interestingly, I have replaced a Garrett Gen 2 GTX3582 that melted a hole through the turbine housing and damaged the turbine etc with a Pulsar equivalent. I supplied on the condition of no warranty as the customer was unwilling to fix the issues leading to the failure. The Pulsar turbo has against all odds survived, so far.
Just cosmetic details.
Should put the comp wheel on a scale and see how much it weighs compared to a Garrett. Would also be interested to see real world back to back tests on things such as boost threshold/ lag/ transient response etc. The cheaper turbo might match in physical dimensions, but that doesn't mean it's going to be as good as the real thing.
As i said, if you don't want one then don't buy one. If you think a theoretical miniscule variation in weight of the compressor or turbine wheel is worth paying triple what i paid for mine then more power to you. I'm more than happy with my poor-mans turbo.
What i find funny is that people on her wank over mamba/kinugawa but when another (much better) turbo comes along you won't even take someones positive feedback on it.
  • Like 1
Mate i wouldn't bother any further, they seem content not to listen to first hand experience so there's no reason to continue trying to explain anything.
  • Like 1
I can tell you what will happen..they will be the same..they would be made by kts...the biggest makers of billet wheels in the whole world..most places get there stuff made there..a lot claim as there own..Its piss easy to make a comp wheel exactly the same..its not even expensive..they are like $120 a piece(or where) if you buy one with a kts trade account
Thats all they do..kinga/mamba they are all kts to
Sorry guys..but these turbos are the shit.....china has stepped it up on a new level
Maybe the only complaint will be the bearing system is not up to scratch with the german etc stuff..but for most people..they wont do that many kms anyway...failing that..you can buy these turbos with aus built quality cartridges already...expect to pay another $1000..still cheap..a g42 for $2500...
Edited by jet_r31
  • Like 3
Ask tao...looks like he is using all same housings etc now...
  • 6 months later...
  • 3 weeks later...
On 11/08/2021 at 11:08 AM, The Mafia said:
Has anyone used the Pulsar SXE range? Any results? I am keen to try one. Specifically the S369 and S372.
Best bet is to check some US forums, i know a lot of mustang guys run bigger pulsar turbos and have good results.
  • 2 years later...
On 11/17/2020 at 6:02 PM, Mick_o said:
You had to take it too literally didn't ya? 🤦‍♂️
The turbo is 100% a critical part as it determines the powerband of your engine, the drivability of the car, but its also a critical part that determines the engines reliability/longevity.
If turbos are an afterthought does that mean if you build your motor  you can just bolt on 1300hp turbo onto the side of it? None of the other internal components need to be a little different?
Pretty dumb huh? 🤔
people like that never get it, never will.
  • Like 1
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
    • I used to love going to Amaroo to watch the HQ series go for broke (eventually stopped due to lack of spare parts) and also the Porsche series.  It was so cool to back your car up to nearly the edge of the viewing barrier and party with your friends, having a bbq and alcoholic/non drinks. It was such a family/mates atmosphere
