ok guyz..i got a problem..a serious problem...
i was wondering if u guyz can help me?
ok i bought my GTR on tuesday ;)
i had to jump start it cuz it hasnt been driven for 2 weeks.
once i jumpstarted it ,i was on my way home.
around liverpool about 30mins into my journey home....
the car just shut it self off in the middle of the road..
making my GTR look like a POS :D
anyway...i manged to push it off to the side of the road and bought new batteries..and replcaed it on the road...the car fired up after the replacement battery...i gave it a bit of rev..
it'll rev till 5K and then stop..once i drop the revs the car will shut it self again...
only this time i can start the car over and over again.
i managed to get it through the busy sydney traffic and to my mechaics place..
today after 2 days i've bought it...the AFM's once though were at fault were not at fault nor the ECU
now i am really running out of ideas...
i was wondering if any1 could help me..
currently the car is running super rich blowing balck smoke like a chimney
and refuses to rev past 3g the car it self has done less than 500 KM's since brought in.
https://www.sau.com.au/forums/topic/48153-help-my-car-is-screwedfunny/
  • 4 months later...
danny i think its the throttle body being dirty...
u got new batteries and also got spart plugs replaced
which means the throttle body is dirty..
u can clean the trottle urself.... only need a tooth brush and some trottle body cleaner
and it shouldnt do it again... if it does then i dont hab a clue
unless u got the wrong batteries
First things first your car only has one battery. There is no way that it will be your throttle bodies (yes you have 6) the rb26 has a multi throttle body setup to enhance throttle response. Throttle bodies being dirty wouldn't be an issue. In extreme cases they mite hamper performance if the airflow is being restricted, but in no way could they cut the engine completely. The chance of it being an o2 sensor problem is also slim as they only trim the mixture. id more inclined to check for air leaks after the afm's in all the intake plumbing that would make it run rich but i doubt it would completely cut out. It depends on how much has been modified on the car too. Like sumone said it could be the ECU especially if its an aftermarket unit playing up. Best thing to do is take it to a fuel system expert.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
