I have 265 on the front, but not on those rims.
I can't imagine you will have a problem with 235/40 on front and 265/35 on the rear.
Worst case guards may need a slight roll depending on height and camber settings for your car.
  • Like 1
On 11/23/2020 at 7:43 PM, huyrcd said:
Hi guys, I was just wondering if anyone knows what the max you can run on the front and rears or any recommendations. I was thinking of going with AD08R's, 235/40 on the fronts and 265/40 on the rears.
A 9.5 inch rim will fit a 275 flush and 285 stretched, however I run 18x8.5+30 with 265/35/18 on factory unrolled rear and front guards without scrub. I guarantee you'll have issues if you lower it or go over potholes.
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
