Hello,
I finally completed the rebuold of my R33 after having spent 10 years on other projects. I'm running circa 550/600bhp, with many mods on the engine (forged, cams, twin 2530s, etc.) and on the car (Cusco diffs, brakes, Ohlins, etc.).
After only 1000miles, I now have a slight cooland leak. I tracked it down and...bingo, I have a crack in the block. I thought for that amount of power it would be ok but facts prove that...errr...no. I'm kinda gutted and I'm now saving for a brand new block, 86mm CP pistons (to keep cylinder walls as thick as possible) and a PRP brace.
Anyway, in the mean time, I'd like to keep using the car and have read one or two good stories about SteelSeal for that kind of problem.
Has anyone ever given it a try?
Tried JB weld. Worked great...for a while. Last sunday I switched the car from mid fun to max fun mode (1.7bar boost) and thrashed the car a lil' bit on nice roads. "Hello, the leak is back!" lol Or not so lol actually...
Where is the crack?
Works better if you take the paint off the block in that area. Clean well and apply jb weld dry. Drain coolant if it leaks while car is off.
Run chemiweld in coolant if you see fit.
Dont forget to send.
20 minutes ago, WantGTR said:
Where is the crack?
Crack is on the intake side, between cyl 4 and 5. I removed the intake plenum, drained coolant, removed paint, sanded the block, apply weld (https://sader.fr/produits/epoxy-repare-metal) and let it settle 48h before refilling the coolant.
It worked. But I guess 550+ bhp and cusco front diff is too much for my block...
That's why I'm now thinking of Steelseal.
Have you tried chemiweld on cracked blocks?
also you may want to drill a hole at each end of the crack to stop it cracking even more. but that will depend on how much room you have and how visible the crack is etc. when i used to repair the gas network the old metal pipes would crack often and before fitting a rubber clamp to seal it we always drilled each end of the cracks to stop them getting longer.
Problem is that even after having grinded the block with my Dremel tool I could barely see the crack. 😞
There is no drip until you build pressure in the system. I've put a 0.9bar rad cap so far. Wonder if a lower pressure cap exists...
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
