Hi guys, this weekend I helped my friend install a Nismo Super Copper mix twin plate clutch into his GTR.
We followed the Nissan Service Manual where applicable, and Nismo's instructions for installing the clutch - Along with using proper ARP hardware for the flywheel, and the bolts supplied by Nismo all torqued to spec.
As well, we replaced the master and slave with new OEM Nissan parts, and vacuum bled the whole system.
The clutch feels great and the dead play is within the factory spec as per the Nissan Factory Service manual.
Clutch drives great on the street no issues.
The issue he is having, when parked on a hill with the car off. If you put the car into first gear, let out the clutch and use the gearbox to essentially hold the car on the hill (so all the load is on the gearbox). You can't disengage the transmission out of first gear by pushing the clutch in (shifter locks into place), the car also won't roll backwards if you push the clutch in.
I've told him not to do this as its essentially not great for the drivetrain and to use the handbrake, place car into neutral so the handbrake has the weight and then put the car into gear.
Apparently it never use to do this with the single plate clutch in it. Is this a normal characteristic of a twin disc clutch or would this indicate the clutch isn't adjusted 100% correctly?
Clutch doesn't seem to drag, in first gear with the clutch pushed in you can free rev it and car won't move.
https://www.sau.com.au/forums/topic/481566-twin-plate-install-on-r32-gtr/
Hi, I don’t have much of an idea on your question, except that it doesn’t sound like a good idea to do that, would be pressure on the gear.
I would like to know what it’s like to drive, heavy clutch? Etc? I plan on putting one in my Gtt. Cheers
  • 1 year later...
Hey there man, sorry to go off topic, but when you installed that twin disc, what bearing carrier did you use? I’m told reduced height bearing carrier should be used in order to  account for the increased height of the twin disc, however Nismo makes no mention of this and did not include a new carrier, only a new bearing. Any suggestions? Thanks
On 2/12/2022 at 4:18 PM, r32-25t said:
Use the factory carrier
Thanks, have you personally used the 18mm carrier with the Nismo twin plate? I’m told a 14mm carrier should be used to account for the increased height of the clutch, which makes sense. Of course I’ll measure all this to be sure, but these carriers in various sizes aren’t easy to get quickly.
Twin and triples generally have a more compact height assemblies than the stock setup, requiring longer carriers. Standard flywheel is massive compared any other flywheel.
14mm is the stock carrier for push BNR32, not 18mm.
They are available in 2mm increments from about 10mm - 32mm. When the entire flywheel and clutch arrangement is shallower than standard, you use a longer carrier. As mentioned twin and triples usually have a longer carrier as they are generally more compact, using anywhere between 18mm and 30mm to move the release bearing face closer to the release fingers. All OS, ATS, Exedy, ORC clutches that I have seen all use longer release bearing carriers.
That said I had a look through the Nismo catalogue, and the only carrier for any model mentioned changing as an alternative part is for the S13 version. None of the kits include carriers either - just release bearing. This would imply that the Nismo coppermix usually is designed around the factory carriers on all other push versions.
I have a 14mm if required.
Oh wow, that confuses me even more, as that is the exact opposite of what I’ve been told. I was under the impression 18mm was the factory height, and the twin plate clutches were taller, requiring a shorter bearing carrier.
Only way will be to measure it up for sure.
On 2/13/2022 at 8:07 AM, BK said:
Absolutely not on both counts.
I have the factory BNR32 bearing carrier as part number 30501-S0200, superseded by 30501-S0284, those are 18mm carriers. Kudos Motorsport said I’ll need the 14mm carrier 30501-N1604, which is the same one that many twin plates come with. Not being argumentative, just want to be sure this is correct
No worries, I know what you're saying and your correct - the "factory" carrier is listed as the 18mm on FAST, but...
I have pulled out 3 x factory carriers from definitely factory fitted original clutches in 89 - 92 32 GTR before and all have been the 14mm carrier, not an 18mm. This I can't explain why - it's just what we've found. Did Nissan originally fit 14mm and changed to 18mm - possibly, but again there is no evidence on FAST of that. Even our own current white 32 with an exedy single was fitted to the existing 14mm, and after measuring it was determined that an 18mm was required and therefore fitted. This is the only time we've actually used an 18mm from memory. It's a tricky situation and if you search SAU there is threads upon threads of this carrier "should" be correct and this carrier "should" be the standard length and the isn't, a bit like this one:
See why I recommended that your might have to measure it to be absolutely sure, as I have found discrepancies with what is supposed to be and what is. Last thing you you want is to have too long a carrier as it will ride the bearing. Are you in a position to measure it up to confirm what you have and if it will suffice or not ?
It is very annoying that Nismo does not provide an actual exact carrier length as per every other clutch manufacturer like ATS twin = 30mm, ATS triple 18mm - 20mm (I use 20mm myself), OS R3C triple 26mm, OS R4C quad 18mm etc. as I have found these examples to be absolutely accurate.
Without waffling on too much more, the only clutches that seem to use the 12mm- 14mm carriers are the dampened and sprung centre twin clutches from OS, which is what a Nismo Coppermix twin is. Their assemblies are much bigger than the solid centre more compact twin / triple / quad plate clutches available that usually use the much longer carriers.
I will suspect that the push Nismo on the BNR32 will be the 14mm as Kudos has alluded to, good luck with it.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
