Guys,
Basically, at what sort of water temperature would you expect to see pressure in the cooling system?
I've got a nismo thermostat, stock, but 5 y/o radiator, stock clutch fan and rad shroud.
Remote oil cooler (keeping factory oil cooler/warmer under oil filter).
Ambient temperature of 22-25 and I see water temps of 71-75 and oil temp the same, I can open the rad cap at these temps and there is no pressure. Coolant level still at top of rad.
Recently changed water pump, and 0.9bar radiator cap and bled it correctly (car jacked up, heater on, bleed screw open, cut down bottle in top of rad, etc etc), took it for a drive up cambewarra mountain (basically a steepish, 6km hill) giving it a hard time, with air con on, and ambient temp of 42 (last weekend!) and it only just nudged 92 degrees at the top.
By the time I'd got back home, it was at 75 deg, overflow bottle level went from half to 3/4. Opened cap and zero pressure.
Oil temps seem to mirror what the water temp is doing
Its also a drift car, and normally takes 5-7 passes before it hits 95ish, usually sitting in staging lane, it will fall to mid 80's within a few minutes.
From memory car has been like this for a long time, but as its never overheated and uses no coolant, runs perfectly fine, no oil/water mix in either oil or coolant side.
I haven't though too much of it, but having just done the water pump I was paying a bit more attention to it, and thought its strange.
Even at 70 degrees, I would have expected a bit of a pssht when opening the cap?
Thoughts?
https://www.sau.com.au/forums/topic/481601-r33-cooling-system-questions/
I've always done mine on the wheels, if it was jacked up at the front then maybe you created an airlock with the angle?  as Sir RB says, try bleeding it again.
On 12/15/2020 at 6:45 PM, SiR_RB said:
I’ve had this happen to me in the past
needed to be bled afew times and became good
Bingo.
Bled it one more time, on ground this time.
Then I drove it to work (50mins drive), then went to a mates place after work, (25 min drive through traffic), got to his place, opened bonnet, felt hose top hose which felt like it had some pressure, opened rad cap (carefully!) and sprayed coolant out.
I'm guessing it just took another bleed/couple of drives to get all of the air out.
Tested it while hot and it holds pressure.
Thanks for the reply's guys
  • Like 1
17 minutes ago, Predator1 said:
Correct me if wrong, but if I was under the impression that if you open the cap when the thermostat is open, then there is very little, or no pressure?
No. The pressure is a function of temperature. The boiling point of water (at sea level) is 100°C. At that temperature the vapour pressure created is 1 atmosphere (101.325 kPa). It is at that point that the steam can jump out of the liquid phase. But at all temperatures below 100°C (and above 0°C if you want to be fussy about only talking about the vapour pressure originating in the liquid phase) there is a vapour pressure. It is very low at low temperatures and it rises to 101.325 kPa at 100°C. And, it increases above 101.325 kPa as the temperature exceeds 100°C, if the water is in a trapped volume (ie, it can't flash to vapour because there is no room for it to do so). That last bit describes a cooling circuit perfectly. Put a 20 psi radiator cap on the top, which will relieve at 20 psi absolute (about 5.3 psi above atmospheric pressure, or ~36 kPa above atmospheric) and it will hold pressure right up until it reaches that temperature and pressure and then the cap will open to relieve the excess pressure, venting hot arse water out into the overflow.
Open the cap when the engine is hot and the thermostast is open and you will instantly allow a quantity of water to flash to vapour, driving steam and hot arse water all over the place. This usually leads to 3rd degree burns and an extensive hospital stay, bill and use of morphine.
  • Like 1
  • Haha 1
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
