Guys,
Basically, at what sort of water temperature would you expect to see pressure in the cooling system?
I've got a nismo thermostat, stock, but 5 y/o radiator, stock clutch fan and rad shroud.
Remote oil cooler (keeping factory oil cooler/warmer under oil filter).
Ambient temperature of 22-25 and I see water temps of 71-75 and oil temp the same, I can open the rad cap at these temps and there is no pressure. Coolant level still at top of rad.
Recently changed water pump, and 0.9bar radiator cap and bled it correctly (car jacked up, heater on, bleed screw open, cut down bottle in top of rad, etc etc), took it for a drive up cambewarra mountain (basically a steepish, 6km hill) giving it a hard time, with air con on, and ambient temp of 42 (last weekend!) and it only just nudged 92 degrees at the top.
By the time I'd got back home, it was at 75 deg, overflow bottle level went from half to 3/4. Opened cap and zero pressure.
Oil temps seem to mirror what the water temp is doing
Its also a drift car, and normally takes 5-7 passes before it hits 95ish, usually sitting in staging lane, it will fall to mid 80's within a few minutes.
From memory car has been like this for a long time, but as its never overheated and uses no coolant, runs perfectly fine, no oil/water mix in either oil or coolant side.
I haven't though too much of it, but having just done the water pump I was paying a bit more attention to it, and thought its strange.
Even at 70 degrees, I would have expected a bit of a pssht when opening the cap?
Thoughts?
https://www.sau.com.au/forums/topic/481601-r33-cooling-system-questions/
I've always done mine on the wheels, if it was jacked up at the front then maybe you created an airlock with the angle?  as Sir RB says, try bleeding it again.
On 12/15/2020 at 6:45 PM, SiR_RB said:
I’ve had this happen to me in the past
needed to be bled afew times and became good
Bingo.
Bled it one more time, on ground this time.
Then I drove it to work (50mins drive), then went to a mates place after work, (25 min drive through traffic), got to his place, opened bonnet, felt hose top hose which felt like it had some pressure, opened rad cap (carefully!) and sprayed coolant out.
I'm guessing it just took another bleed/couple of drives to get all of the air out.
Tested it while hot and it holds pressure.
Thanks for the reply's guys
  • Like 1
17 minutes ago, Predator1 said:
Correct me if wrong, but if I was under the impression that if you open the cap when the thermostat is open, then there is very little, or no pressure?
No. The pressure is a function of temperature. The boiling point of water (at sea level) is 100°C. At that temperature the vapour pressure created is 1 atmosphere (101.325 kPa). It is at that point that the steam can jump out of the liquid phase. But at all temperatures below 100°C (and above 0°C if you want to be fussy about only talking about the vapour pressure originating in the liquid phase) there is a vapour pressure. It is very low at low temperatures and it rises to 101.325 kPa at 100°C. And, it increases above 101.325 kPa as the temperature exceeds 100°C, if the water is in a trapped volume (ie, it can't flash to vapour because there is no room for it to do so). That last bit describes a cooling circuit perfectly. Put a 20 psi radiator cap on the top, which will relieve at 20 psi absolute (about 5.3 psi above atmospheric pressure, or ~36 kPa above atmospheric) and it will hold pressure right up until it reaches that temperature and pressure and then the cap will open to relieve the excess pressure, venting hot arse water out into the overflow.
Open the cap when the engine is hot and the thermostast is open and you will instantly allow a quantity of water to flash to vapour, driving steam and hot arse water all over the place. This usually leads to 3rd degree burns and an extensive hospital stay, bill and use of morphine.
  • Like 1
  • Haha 1
    • Hmmm, what do you mean by getting weaker? And where did you get that test done? I've been wondering about my battery because the cold starts crank super slowly. The voltage is fine. Not sure if cranking amps can be checked at home. Battery is 4+ years old.
    • No. The simplest wastegate hookup, with no solenoid or other form of "boost control" (ie, control over your boost control, if you know what I mean) is a single hose, direct from the turbo outlet/hot pipe, straight and only to the wastegate actuator. It is that pressure signal that drives the wastegate to open, providing the boost control (and by "boost control" here, I mean, limiting how high it can go, which is essentially the spring pressure of the actuator). You only end up with tee pieces and alternate flow paths once you start adding things to the boost control system to allow you to determine how much of that boost signal makes it to the actuator. There are so many ways to do that that there is no single way to run the hoses and tees and the like. If you have a stock boost solenoid, then all it does is either allow all the boost signal to go to the actuator, or open up to allow some of it to bleed off. There needs to be a restriction in that bleeder to allow only a small amount to bleed off. And in a stock system, that would then be plumbed back to the turbo inlet (for "emissions control" reasons). That is actually what that nipple on your BOV return pipe could/would be for. If you have an aftermarket boost controller and solenoid, then the above is mostly true, but there is no need for a restrictor in the bleed, because the solenoid is pulse width modulated to create a variable bleed off. The air that escapes from the bleed can either be vented, or also returned to the turbo inlet. For emissions reasons it should be returned to inlet, but the amount of air being vented is so small that it really doesn't matter (either from an emissions perspective, or from an air-fuel ratio affecting perspective).
    • And other times you just need to go buy bigger injectors?
    • Yup. I actually just blew my turbo. LOL.  should have checked this thread before today. i also have no boost solenoid. so it should be...one line from wastegate to turbo inlet, and a T somewhere in that line that connects to the wastegate return pipe?
    • It's recommended, however I can assure you a good amount of people don't bother. FWIW, the OEM battery lasted 4.5 years and I changed it prematurely too, I reckon could have stretched it to 5 years.
