Just putting it out there, interested in hearing peoples thoughts on this.
For a GTR with where they are going and with ‘purity’ possibly becoming more important nowadays.
would you prefer a 26 based bottom end or a 30 based bottom end?
and why?
purely for discussion, let’s not go to war over this! Lol
https://www.sau.com.au/forums/topic/481613-rb26-or-rb30/
For a motor that will feel better everywhere in all usage models, a 30. Every time. The only way that it is let down compared to a 26 is that elastic need for revs and the extra little buzz you get from running to 11ty rpm. But I'd rather more torque and power everywhere.
Put the 26 block in the shed for later purity restoration.
Although....in a 32, I am against the shitty mods you have to do to squeeze a 30 into the engine bay.
https://www.sau.com.au/forums/topic/481613-rb26-or-rb30/#findComment-7944070
3 hours ago, Stixbnr32 said:
Yeah if i was to do my build again id still go 26 block in my R32 but id prob go a nitto 2.8 stroker.
Everything fits under the bonnet and you get a decent bump inpower/torque.
I would also use a PRP brace.
THIS. I kinda regret doing a 3.2 mainly due to fitmet issues. I just hate chopping shit up, but thats just me. I'm sure when mines running it will be well worth it, but if i was to do it all again, I'd def do a high revving 500kw 2.8.
  • Like 1
https://www.sau.com.au/forums/topic/481613-rb26-or-rb30/#findComment-7944129
Cheers for the responses, looks like a 26 based bottom end wins the popular vote.
To ‘let the cat out the bag’ I’ve been considering building a bottom end and was undecided which way to go.
My car is currently fitted with a 30 bottom end.
anyway, the opportunity has come up to purchase a JHH built 2.7 motor, built in an N1 block with their Raceport head package.
My reservations are, my current setup is so good, torque everywhere, good response and fast enough for me, but this set up isn’t where I’m going with the build. I want a 26 block, but I’m nervous I won’t like it compared to what I currently have.
the struggle is real! Lol
  • Haha 1
https://www.sau.com.au/forums/topic/481613-rb26-or-rb30/#findComment-7944133
1 hour ago, Predator1 said:
If you already have a 30, then stick with it. 2.7 will see a noticeable amount of lag, plus you might need a smaller turbo.
Depends on what you really want at the end of the day. How much power does your 30 make atm?
Car make 440kw on 98 @ 20psi
and 580kw on E85 @ 32 psi
Obviously the powerband will move up the rpm range in the 2.7, but the 2.7 will happily Rev to 9500rpm and the 3.0 is restricted to lower rpm.
https://www.sau.com.au/forums/topic/481613-rb26-or-rb30/#findComment-7944137
5 hours ago, GTSBoy said:
I dunno man. You've already done what's needed to put a 30 based engine in. The damage is done, the pipework is set up.
At your power level you're really going to feel the difference if you drop 10% capacity.
That’s where I’m stuck, the 30 is in and is a great motor. Was built well, but a part of me really wants a 26.
then on top of that, I’m nervous I’m going to be disappointed.
AND at some point, I will be going back to a 26 block, just this opportunity has come up now and I was hoping to enjoy the current set up for a few years first.
https://www.sau.com.au/forums/topic/481613-rb26-or-rb30/#findComment-7944162
This is me, if I was building a motor, then I would build a 2.7/8. The 30 was in it when I bought the car, but it’s proven to be a very good motor. So now a part of me says stuck with what you got, you know it’s good, it’s set up and it works, and the other part says, build it how you want.
Now it seems from the responses here that most, if building from scratch, would go with a 2.7-2.8 over a 3.0/2
https://www.sau.com.au/forums/topic/481613-rb26-or-rb30/#findComment-7944181
The torque of the RB30 is real. My mates 32R makes 440~awkw @ only 18psi with no timing, and that thing had virtually no lag. Even going uphill, that thing would just haul from any gear/revs. In contrast, a 2.6 or 2.7 or eve a 2.8 would see considerable lag before it starts to boogey. IMHO, stick with what you have, and enjoy life.
https://www.sau.com.au/forums/topic/481613-rb26-or-rb30/#findComment-7944182
Another thing, guys who have gone from a standard crank to a billet crank, how much difference does it make? I’ve read that the billet Rev much smoother/quicker and feel very sharp on the throttle?
https://www.sau.com.au/forums/topic/481613-rb26-or-rb30/#findComment-7944183
Yeah I hear you, this is my car now, even with the 68/70, it’s on when you roll the throttle, rpm doesn’t really matter. As a street car, it’s probably as good as you’d want, but because I’m a little weird I think ‘As a GTR’ where do I want it?
shouldnt a GTR have lag, isn’t that part of the driving experience, lol
If I do this, it won’t be one engine out and one in, it will be engine bay respray, blast and coat subframe, replace bonnet, re wire engine bay. I will bring the bay up to a standard I want it. It presents well now, but It’s no where near finished to a level I’m happy with.
But thanks for the the input, I appreciate peoples opinions on this, helps to give perspective and give me an idea what to expect if I move forward with this.
  • Like 2
https://www.sau.com.au/forums/topic/481613-rb26-or-rb30/#findComment-7944184
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
