I’ve done a search but haven’t been able to find anything. Is there anyone on here who understands turbos who would be able to explain the difference in how these turbos would behave / respond compared to one another.
obviously housings can affect this so let’s compare
1. 6870 gen 2, 1.0ar T4 divided rear
2. 6875 gen 2, .96ar T4 rear
now I know the 6875 is rated a little higher, will it actually make more power and how much will you sacrifice in lag?
https://www.sau.com.au/forums/topic/481617-6870-vs-6875/
1 hour ago, r32-25t said:
Wouldn’t the compressor maps be the same for the fact they’re the same compressor wheel and housing
Not sure, on their website says the 68/75 is a more modern design turbine
https://www.sau.com.au/forums/topic/481617-6870-vs-6875/#findComment-7944123
53 minutes ago, SiR_RB said:
68mm comp wheel will max out well before the 75 rear
So there would be no reason to go 6875 over 6870?
this is what I’m trying to find out, I’d like to actually talk to someone who is really switched on with turbos and not tied to any one brand. When I sell my motor I’ll probably let it go with the entire hot side. As my new motor is a 2.7, I’d like a turbo that is responsive, but can still make decent power and give a decent push when turned up.
https://www.sau.com.au/forums/topic/481617-6870-vs-6875/#findComment-7944315
Why not the 6466 then ? I tossed up going the 6870, then I thought why ? People are making 500 - 600rwkw with them and it will always be more responsive than the 6870, so I went the 1.00a/r 6466.
  • Like 1
https://www.sau.com.au/forums/topic/481617-6870-vs-6875/#findComment-7944320
As Bk said, seriously consider the 6466
if you have a full house head and a decent rear (1.00+ in size) I have seen the 6466 push 580ish kw and would be an absolute rocket on the street with amazing response with the 2.7
https://www.sau.com.au/forums/topic/481617-6870-vs-6875/#findComment-7944326
This is what I’m thinking, but I’m also not a Precesion fan boy, so I’d like to know all my options, I’ve heard good things about the Garrett 3584rs, mixed reviews on the new G series, good things about Borg Warner, I’ve also looked at Xona rotor?
https://www.sau.com.au/forums/topic/481617-6870-vs-6875/#findComment-7944327
Did 146mph on the 580kw blue line dyno graph
have not been back since the tweaking of exhaust setup, also going a CNC Shimless head at the moment and redoing the pipework etc.
Keen too see how far we can push the 6466
  • Like 2
https://www.sau.com.au/forums/topic/481617-6870-vs-6875/#findComment-7944332
What size engine is that on?
https://www.sau.com.au/forums/topic/481617-6870-vs-6875/#findComment-7944333
My problem with the new Garrett turbos is there’s currently no twin scroll option
https://www.sau.com.au/forums/topic/481617-6870-vs-6875/#findComment-7944334
15 hours ago, SiR_RB said:
What rear is on the 64 mate
it was .84 with the 146mph
Have since gone 1.15 but did not get any massive changes, have since gone to 4" dump and CNC head to assist unlocking a few more ponies.
goal is 150mph on a 6466
https://www.sau.com.au/forums/topic/481617-6870-vs-6875/#findComment-7944360
What gearbox?
  • Like 1
https://www.sau.com.au/forums/topic/481617-6870-vs-6875/#findComment-7944366
What boost was that at mate?
https://www.sau.com.au/forums/topic/481617-6870-vs-6875/#findComment-7944368
Had a chat with the guy from Garrett turbos yesterday about turbo options, he recommended the G30 900hp or G35 900, said they would offer good response and solid top end, another option is the G35 1050hp, this turbo is to supersede the 3584rs and will be released in a T4 divided rear housing option in the 1st quarter of 2021.
https://www.sau.com.au/forums/topic/481617-6870-vs-6875/#findComment-7944382
