  • 7 months later...
Late post but im putting together another rb for the drag season and have came across these pulsar turbos you guys maybe interested in, I have buddies that are beating the piss out of them on there jz's, they seem to hold up just fine and are 1/3 of a price of precisions. im currently on a 6466 but looking to make 900whp. im going to try the pulsar 7170 not even a 1000 quid!! good bang for buck
On 05/01/2023 at 1:54 AM, GTSBoy said:
I think the consensus is that the Pulsar turbos are good examples of cheap Chinese turbos, but that they are still cheap Chinese turbos, in that the tolerances/clearances etc are not....great.
Are there any good examples of this in terms of media we can see?
I've seen a couple of "just happen to be Garrett dealers/sponsored by Garrett dealer" people make these claims but so far have been involved in a pretty solid amount of Pulsar turbo based builds without seeing this issue.  The only issues I have seen have been regarding needing to make sure things are done up properly, ie - not assuming vbands are done up, or turbo speed sensor plug screwed in properly etc.   Have heard of 3rd party folks who are doing mix-and-match sells of Pulsars selling them with the wrong housing, ie GT35 turbine housing with GT30 turbine but that's not a build quality thing and could just as easily happen with the same people selling legit Garrett bits.
Edited by Lithium
And, to be fair, that could be the sole source of any noise I have heard.
So far I've not seen any reports from people I'd call "neutral" buuuuut I'm obviously open to finding out if they are something I should be more apprehensive about sticking up for.  I have nothing to gain personally, not a dealer or anything - like yourself just like trying to give people "what I know" to try and help them be best equipped to make the right calls... the whole "are you ok with buying a copycat" is a different ethical decision best made by the buyer.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
