Hi All,
I have recently changed my dash to one of Link's new digital dashes, managed to get the speedo and odometer working by using the S13 speedo sensor as they run a analog to digital converter and sends the signal to the ecu then onto the dash. My problem now though is that i feel like i have no power steer at low speeds, which i am guessing with the factory setup the speedo drive cable goes to the dash then from there sends a signal to the hicas pump( i have removed hicas)
Unfortunately my mechanic isnt really too familiar with it so we are a bit stuck. Any ideas? im guessing in theory i need to get the speed signal to the hicas ecu?
Regards
Jeff
https://www.sau.com.au/forums/topic/481629-r32-gtr-power-steer-issue/
Really interesting how different people feel the power steering impact. I haven't had speed input in my 32 GTR for years and am happy with the weight. Yes it is heavier than a modern car but not unmanageable.
Sorry I can't help with the 33 GTR wiring, I've only ever seen manuals in japanese not english
If the ECU is getting a speed signal then the HICAS CU is getting it. They're all on the same bus. (So long as you haven't damaged the appropriate wiring, that is).
The signal goes nowhere near the "pump". There is a solenoid valve on the front rack. That is PWM controlled by the HICAS CU to provide assistance from hydraulic pressure. It could be stuffed. Check for voltage there and see if it is still even receiving power. If it is not, then the power feed wiring could be at fault. I burnt that wire when my oxy sensor had a severe problem and damaged a couple of wires (they run in the same loom).
Something weird has happend, when infirst start the car, i would have powersteering for about 3kms then steering would get heavy and stay like that until i start the car again.
That's because the HICAS computer waits for a predetermined period of time to receive a speed signal and confirm all other sensors. If it doesn't get all correct signals, it kills all power steering assistance. It really does appear that your speed signal is not correct at the HICAS unit.
You really need to go into HICAS diagnostic mode and check the fault codes from the unit. I'm not sure how you're going to do that without the HICAS dash indicator to flash codes, which I guess you don't have with your new Link dash.
If you do have a HICAS indicator, there are tutorials on how to enter it and read the fault codes on SAU.
Agree it mght be the only way to go to diagnose the HICAS now. That said, I don't know where Jeff lives in NZ but getting access to a proper scan tool might not be so easy for him. We all don't live in a major city.
I know if I needed one here I'd have to go 1500km down to Adelaide to find a workshop with one, because I know the only ones around here would be factory dealerships who no way would connect to any import.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
