Is it possible to import an R35 Gtr from Japan now?
I'm aware some of the better known importers have made reference to this as being possible, but I see no official mention of this anywhere. Furthermore, I don't see a Raws listed on the dotars website who could comply an r35.
There are also none for sale on carsales, but I doubt this is simply because there is insufficient price difference between Japan and Australia. I'd think it supports the theory that these still aren't eligible for import yet.
Given I've now missed out on a shmick r33 gtr vspec 3 which would have set me back 90k, and then an r34 gtr v which was on the wrong side of 280k.... It seems ludicrous that I'd continue to look at cars in that price range before considering the newer, better r35 gtr.
Cheers
Jez
https://www.sau.com.au/forums/topic/481655-importing-r35-gtr/
Thanks all.
SEVS eligibility is one thing.... But an accredited RAWS that has submitted the evidence pack, been approved and now has plates available is probably another.
Because the dotars 'search for a raws' still has zero entries for the R35 gtr.
http://raws.infrastructure.gov.au/rawswebpublic/RAWPubSearch.asp#results
And the fact that I never heard of a single compliance workshop that does these cars... Makes me think some import brokers are perhaps a bit 'ahead of the curve'
(I'm sure someone would be welcome to buy and provide the test vehicle for the evidence pack... But I'm too consumed by other things to want to do that).
My guess is that the lack of price differential between jdm and adm r35 gtr is what has deterred compliance shops from pursuing the R35 gtr. After all, not only do you have the snafu instrumentation issue to deal with (all in Japanese) but the lack of service history, the inability to see the car, yadda yadda yadda.... I guess you'd want a 15k discount on the local product in order to want to buy the jdm derivative. And as Joshua points out, only being able to get the earliest model is a further drawback.
Oh well...... Back to the drawing board....
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
