My partner's 2004 350gt skyline won't start we just started it to move it into the shed then we went to turn it on again and now it won't start we have lights coming on and everything but won't crank all it does is buzz
We have tried the starter motor it's not that
Check fusses not that
And we have checked the battery not that
And also check fuel pump it's not that
This has just happend out of no where it hasn't done this before and it's our daily
https://www.sau.com.au/forums/topic/481656-my-partners-car-wont-start/
It does sound like a battery, when you attempt to crank, do the lights on the dash stay on at full brightness? or do they go very dull/off?
If they stay on full, it points more toward the starter motor, if they go very dull, then look more toward the battery.
How have you eliminated the above items?  replaced them?  tested them?
  • Like 1
Whoa back up son, the starter motor is actuated by a relay have you checked the relay? Have you applied power directly to the starter motor? Does it rotate? Does the solenoid actuate ? Does the relay click, or is that your Buzzing sound. Are you sure the battery is ok, you must load test batteries a simple voltage measurement is not good enough.
  • Like 1
For sure, when I say 'point toward the starter motor', I don't mean it will be the starter motor, but including all the components associated with it, including relays, wiring, grounding, etc.
  • Like 1
FWIW my M35 cranks hard even when it doesn't have enough electric power to start. First thing i'd do it try a jump start after double checking battery connections and charge. IIRC the battery should be 12.6 volts when fully charged.
just making sure you have checked the connections to the starter that the nut or clip may be loose? wiring maybe to the plugs to the starter. and yeah of course make sure you have voltage or try boosting it with another vehicle. kick the bitch a little bit.
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
    • You can get them with the worm drive rotator but I was too tight to pay another $250-$300 so manual labour it is! I don't think it will be too hard to rotate though.
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
