My partners car won't start
My partner's 2004 350gt skyline won't start we just started it to move it into the shed then we went to turn it on again and now it won't start we have lights coming on and everything but won't crank all it does is buzz
We have tried the starter motor it's not that
Check fusses not that
And we have checked the battery not that
And also check fuel pump it's not that
This has just happend out of no where it hasn't done this before and it's our daily
It does sound like a battery, when you attempt to crank, do the lights on the dash stay on at full brightness? or do they go very dull/off?
If they stay on full, it points more toward the starter motor, if they go very dull, then look more toward the battery.
How have you eliminated the above items?  replaced them?  tested them?
  • Like 1
Whoa back up son, the starter motor is actuated by a relay have you checked the relay? Have you applied power directly to the starter motor? Does it rotate? Does the solenoid actuate ? Does the relay click, or is that your Buzzing sound. Are you sure the battery is ok, you must load test batteries a simple voltage measurement is not good enough.
  • Like 1
For sure, when I say 'point toward the starter motor', I don't mean it will be the starter motor, but including all the components associated with it, including relays, wiring, grounding, etc.
  • Like 1
FWIW my M35 cranks hard even when it doesn't have enough electric power to start. First thing i'd do it try a jump start after double checking battery connections and charge. IIRC the battery should be 12.6 volts when fully charged.
just making sure you have checked the connections to the starter that the nut or clip may be loose? wiring maybe to the plugs to the starter. and yeah of course make sure you have voltage or try boosting it with another vehicle. kick the bitch a little bit.
 Share
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
