Hey all,
Recently installed a Viper GPS tracker into my car and it seems that if i turn the alarm on, it will drain my battery within a couple of days.
If i don't turn on the alar, and just manually lock my doors, the battery doesn't drain as fast.
I have it hooked up to a trickle charger now, but i wanted to know if this is normal behaviour for a tracker?
Thanks,
Colin
https://www.sau.com.au/forums/topic/481658-viper-gps-tracker-draining-battery/
Not necessarily "normal" behaviour. But there might be nothing "wrong" with the tracker. It's far more likely that your battery is crap and can't tolerate what would otherwise be a completely acceptable current drain.
Put an ammeter in the power lead to the tracker. Report how much it's using.
Hey would you be able to recommend a battery that would suit? I have a century battery that is less than a month old that keeps going flat whenever I don't have the trickle charger on it.
34 minutes ago, GTSBoy said:
I would have said Century. If it's only a month old then it should be fine, unless you have somehow managed to drain it flat too badly too many times already and killed it.
Why don't you do the current drain test?
No idea how to to be honest, would you able to elaborate?
Also wouldn't be able to tell which one would be the power lead to the tracker.
Thanks,
Colin
Ammeter is a function for measuring current on your typical multimeter, which can be had for ~$10 off eBay or your local Jaycar equivalent.
Find the fuse that runs the tracker. Remove the fuse, put the ammeter across the terminals where the fuse was. Now you're in the circuit and can measure the current it's pulling.
I have a GPS tracker as well and use a trickle charger on a new battery (well not so new now).
Unfortunately you know that the tracker is running 24/7 and this requires current - this WILL drain the battery if the car is not used.  It should be over a week on a small battery (like mine).
If youre not driving a car its advised to use a trickle charger anyway.
Thanks.
  • Like 1
I've had my tracker disconnected to see if that is the issue. Havn't had an issue with my battery since ~ 2 weeks, driven only twice. Will have to get an electrician to have a look at it i think.
Thanks,
Colin
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
