Hi all
I recently purchased a R34 Vspec, and I want to get a set of new headlights, but i'm very confusing on the part # from Nissian, I tried to search on this forum and online, but unable to located a clear answer. So i really need your help on this or pointing me into the right directions.
1.)Is R34 Vspec and R34 Vspec 2 all share the same Headlight Housing?
2.)Can I just replace the headlight housing instead of the headlight Assembly, the pricing for the Assembly is double the price of headlight housing?
3.)Is there any different between R34 Vspec housing between the late model and early model?
Thank you so much for all you guys help.
https://www.sau.com.au/forums/topic/481659-r34-vspec-headlights/
2 hours ago, laicosmo said:
Hi all
R34 VSpec 1 and VSpec 2 do not have the same part number for headlight housings. Not sure where you got that. "Housing assembly" is the part you're talking about, "Headlight Assembly" includes things like the HID ballast, bulb caps, bulbs, etc. Whether you need a housing assembly or a headlight assembly depends on what's wrong with the headlight. You may not even need a housing assembly if your problem is just that the lens is damaged. If you want to swap to Xenon from Halogen then you will want an entire headlight assembly.
I believe the difference between the 1999-2000 headlight assembly vs 2000+ headlight assembly is this: "Xenon headlamps change from Series 1 cars to Series 2 cars. Series 2 cars (lense code 1618) have shadow chrome inserts as opposed to champagne accents on the Series 1 (lense code 1601) cars. Series 2 cars lost the light level actuator motors from housings activated via cabin switch."
Source: http://gtr-registry.com/en-bnr34-specs.php
There may be smaller differences though. I suspect this is why the some housings are half the price of others.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
