Hello. I have recently bought an RB25. It claimed to have poncams but no specs were available. Removed covers to find both intake and exhaust are 264/264 with 8.5mm lift.
Looking to degree the cams- but I can't find any info on a 264 intake and exhaust.
Are these real cams? Or knockoff? Never heard of fake camshafts but there is fake turbos so it's arguably easier to fake cams...
Cheers!6B0C81AD-4D30-45C5-B6DB-3DDDF8131D69.thumb.jpeg.6ca6daeb767c5dfae92fb0ae3b8da4ec.jpeg
https://www.sau.com.au/forums/topic/481662-fake-poncams/
1 hour ago, r32-25t said:
He retired last week or the week before
Really ? That sucks, they had some really good grind selections. Only just sold some new Camtech RB26 cams last week for $500. 🤦‍♂️
Kelfords only now I guess ?
https://www.sau.com.au/forums/topic/481662-fake-poncams/#findComment-7944615
Just now, CLEM0 said:
They certainly don't seem current- but I can't find any specs to degree them in!
Just put them on the same LSAs as any other 264° cam, or choose an LSA halfway between the typical 256° and 272° cams' specs. Tighten or widen the LSA by a degree or two depending on how you want the engine to work.
https://www.sau.com.au/forums/topic/481662-fake-poncams/#findComment-7944623
Ages ago I was told that Tomei cams don't need to be dialled in and should always be set to zero ...for RB25 Gtst's.
This was after we dialled in [from memory 5 degrees [could have been 10, it was 20 years ago]] and it ran like shit.  Asking around everyone said to set to zero and it will work.....we did, and it did.
I could be wrong for your motor, but if you don't see gains then zero is your answer.
But Dose Pipe and GTSboy will know more.
https://www.sau.com.au/forums/topic/481662-fake-poncams/#findComment-7944624
Yeah I heard that too- but these seem fairly big for what most run. Probably going to get some stock cams for now- runs like a dog off boost and isn't fun, 120psi across all 6, shitty idle etc
Likely they are 0* right now- no adjustable cam gears so I think for street use stock is fine.
https://www.sau.com.au/forums/topic/481662-fake-poncams/#findComment-7944626
  • 1 month later...
    • The fuel pump bracket just slides straight up.  Below is a pic I stole off a site. But basically put hand in for fuel pump, wiggle it all about a bit while pulling up.
    • Went digging Duncan, there's another "item" that sits down under the plenum that the second pipe from the IACV goes down to. I believe that's the one that is apart of the cold start portion, and it then comes back up under the middle of the factory top plenum. I believe you will find it is unneeded on the forward facing plenum on Cheryl.   I just went digging further for some pics on the location of the one way check valve, and found something that confirms my thoughts from the first half of this point. I feel you can just block off that port that is coming down.     I can also confirm, the other line that you were thinking for vacuum that will just need a one way valve put into Cheryl is 100% correct too. The one way valve is normally screwed into the back of the factory inlet plenum.
    • You’re an absolute legend man. Cheers.
    • The rule of thumb for any GTR thats doing a single turbo conversion is..... seqy... and when i say seqy, i dont mean the pos PPG either. *flamesuit on*
    • The ECU does care - it runs the engine as two banks of 3 wrt O2 trimming. So you have to give it the right one. Um....look at the engine bay pictures in the GTR manual? I think you can make them out there. I think the physical wiring diagram might also help.... Actually, I just looked at the engine bay wiring diag. It clear shows the shapes of the connectors. I'd say that R means rear. According to the rest of that diagram, pin 2 of the R one turns up at terminal 55 of the ECU. Which is.....the rear one.
