4 hours ago, seriesII said:
does this mean mine are r34 brembos and gtr rotors?
No, because the original would be too small for either rotor. It is possible to bend the cover back away rather than cutting it (that's what I did to put 296 and them 310mm rotors on a 280mm car). The offset change on the disc itself with the Z33 rotor might mean that you don't need to do anything. I can't remember which way the disc moves, but if it moves outward then there's your magic.
  • Thanks 1
I have Z33 front calipers and rotors on my GTT and I did not need to do cut the lip on the dust covers. There is just enough room to accommodate them. They may have touched on a few spots which was easily bent away with a flat screwdriver.
  • Thanks 1
14 hours ago, seriesII said:
when I cared about sharing knowledge 🤣🤣 ..so gets like that
Oh you know back then you could have easily bought 350Z Brembo front calipers with used OEM rotors for $500 or less.
A while after I wrote that stupid article the price of 350Z Brembo calipers shot up lol.
It's official now, it's all your fault. Lol🤣
  • Haha 2
Yeah I read that article and then went and bought a set of front and rear Z33 calipers with used rotors for $700. I looked into trying to fit the rears but there were no adapters available so got some R33 GTR rears which bolted straight on.
  • Like 1
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
