i have a question on an engine swap and i cant seem to find anything related to it so i thought id come here, so i wanna put a worked 304 fuel injected 5ltr v8 into my r33 series 2 gtst.
all i want to know is will the old v8 fit into the engine bay without having to modify it heavily?
https://www.sau.com.au/forums/topic/481671-r33-engine-swap/
You just have not looked very hard. (Jesus, I say that a lot ) I googled Ford V8 in Skyline  there are many examples. Even a R34 that has a 410 cu Ford. Seek and you will find mate. If a 410 fits in a 34 then yes a 304 will fit. But as GTSBoy would say" WHY"   LS3 bigger, better and mucho information on how to do it.
https://www.sau.com.au/forums/topic/481671-r33-engine-swap/#findComment-7944674
@Rusty Nuts Thanks for answering the question boss man, and I didn't find anything to do with the 304 swap im new to the mechanical side of things and i dont know anything about Ford motors idk what a 410 is tbh grew up round Holden people thats why seeing a Ford motor in a 34 in some article wouldn't help me i didnt know the 410 was the same size as the 304.
And i dont wanna go with an ls because I love my Aussie built holden motors dont wanna use the ls its boring everyone puts em in everything they're everywhere and iv not seen a 304 in skyline before, im essentialy taking the motors out of both my cars and swapping them into each other, so rb25det powered vs ute and a aussie v8 powered r33.
  • Like 1
https://www.sau.com.au/forums/topic/481671-r33-engine-swap/#findComment-7944675
Ford 410 cubic inch is a big block motor, they are huge, way bigger than any aussie v8. If you want to do the swap, Follow your dream mate, and all power too you. At least the VS RB25det swap has been done and plenty of info out there.
  • Like 1
https://www.sau.com.au/forums/topic/481671-r33-engine-swap/#findComment-7944676
https://www.boostcruising.com/advice/404393-VS-UTE-Engine-Conversion-TO-Rb25det.html  you will find some good info such as the following paragraph
fitting a rb20det into a vp for the simple fact i had a ute with no motor and rb20det sitting there. use the vl crossmember with one vl engine mount and one skyline mount. fit the commodore crossmember to the nissan box and elongate the holes and it will fit. does require custom tailshaft. use a vl powersteering pump and vl power steering lines. one of the supports from the engine to the bottum of the gearbox needs modding to clear the steering rack. rad hoses are also hard as the commodore has narrower engine bay so standard skyline ones hit but you can just use a vl radiator.im currently fabricating allow hoses so i can run them where i want. i also am using the commodore alternator so all the existing wiring plugs back in. doing the clutch gear is the hardest. is yours auto or manual and whats its gonna be. my issue is that my vp was manual with a cable that pulls and the box is hydraulic with a slave that pushes which means modding the pedal box to accept a hydraulic push type setup and you are restricted badly by room issues.then just simpler things like fuel pumps but commodore pump will handle a stock rb engine. then theres FMIC and piping which is not the easiest and ive also put a engine oil cooler in the front with braided lines and its all a bery tight fit. all in all its not as easy as i thought but is doable.
  • Like 1
https://www.sau.com.au/forums/topic/481671-r33-engine-swap/#findComment-7944678
Doing things to be different or unique always ends up being fairly pointless and a wild waste of money.
Yes ls engines are common, for a reason. You have to spend heaps of cash on a 304 to make decent power, and what have you really achieved?
Your engine swap between two cars makes so little sense, just leave the engines in the cars they are already in and use the time and effort on something productive. That's my 2 cents that you didn't ask for.
  • Like 1
https://www.sau.com.au/forums/topic/481671-r33-engine-swap/#findComment-7944686
I understand the money cost of a 304 but I'm not after some 1000kw 304 I simply want a 304 swapped r33 with say 300kw I know it's not hard to get that type of power my mates vs wagon pulls that no problem.
And as for what I would achieve? To most nothing but im not building my cars for others im building them for me.
If somethings easy its not worth doing, words to live by lad.
https://www.sau.com.au/forums/topic/481671-r33-engine-swap/#findComment-7944690
Electrically its really pretty simple. There'd be no swap reason this wouldn't work if the dimensions are remotely similar (are they? I do not know).
The kicker of course is legality. Does the 304 put out similar emissions to your R33's RB25? The target must be met by the standard of the chassis, not the engine. Meaning your engine may pass in a 1988 commodore, but will be illegal in a 2000 Skyline etc. Unless it meets the year 2000 requirements.
The LS itself is extremely dumb and I am assuming an older V8 is even "dumber" so it'll definitely 'work'.. as long as it fits and depends heavily on what you want to keep.
I kept AC, and power steering, I cared about OEM dashes working OEM. Most importantly I cared about legality. Depending on how much you care about this depends heavily on how complex a job it will turn out to be.
  • Like 2
https://www.sau.com.au/forums/topic/481671-r33-engine-swap/#findComment-7944699
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
