1 hour ago, GoHashiriya said:
That's alright. I have got a copy already, albeit only the R34 one which presumably doesnt cover my 32 trans. Thanks for the reminder though as it did slip my mind.
good on yeah mate. glad to help when i can hows things going with the car.
Honestly, It's gonna take me about a month to crack on with this job. I've gotta move house next month which will hold me back. I'm going to try and do coilovers, hicas lock and arms next weekend, plus get the wheels mounted and aligned. It's the wrong order I know, but I don't wanna have the car in an immovable state before moving.
I appreciate everyone's input so far and will be sure to update this when I make some progress.
yeah forsure bro dont rush it. i rushed my build spent way to much creates stress and takes the fun out of it. go at your own pace with fixing it and just enjoy. more to life than cars as much as we do love them.
  • Like 1
Over the weekend I had a glance under the car and found the neutral switch - located just forward of the shifter - isn't plugged into anything.
I've tried searching but have found limited results indicating the colours or location of the wires I need to plug this into. If anyone can point me in the right direction it would be much appreciated.
The best description of the wiring I've found is this:
"When you (have) disconnected the loom from the gearbox, you should have disconnected 4 plugs. The green and black plugs on the PNP switch, the plug for the speedometer which is grey with an orange and a black wire, and a second speedometer plug, which is brown. I’ll start with the PNP plugs.
You only need the black plug. On the black plug, there are 3 wires that you need. The red wire for the reverse switch, this also needs a earth wire that you can splice from the earth (black wire) that goes into the speedometer sensor. The other two wires that you need are the brown with yellow stripe and green with white stripe. These are for the neutral switch."
The thread is regarding an R34 auto-manual swap. Do these wire colours apply across the board for the 34?
Apologies for the poor quality pic, it was relatively tight under the car.
There's another switch on the side of the gearbag, looks like the reverse switch. THAT is the neutral switch. What you have pointed to as the neutral switch is just the loom connector.
But more importantly, that gearbag doesn't look like an RB25DET box. Looks like RB20DET. That lettering cast in in behind the reverse switch says RP71, right?
Compare with below image of RB20 box
https://www.jdmenginesimport.com/images/EnginePics/Full/339_4_IMG_4243.jpg
  • Like 1
You're correct, it's an RB20 box - a questionable choice for a swap into an ER34. I know, I know - a budget for a suitable transmission is in the works.
The switch in question for me is the one just forward of the shifter:image.png.b09fd2dd3b4fcaffcedea62251ab707b.png
    • Nah, I'm not an a-hole, ha ha!   I do like the colour match. Some of the carbon fibre wraps are quite freaking horrible. There's one a local company I know uses, and it looks damn good! Also very very expensive per metre to buy! ha ha ha It might be cheaper to respray the roof than use the good CF Wrap, ha ha!
    • Please noooooooo 😭 As for wrap, no thank you mate, I've seen and used "carbon fibre" wrap before, and for these hard tops, they look soooo good when colour matched Like this >>>
    • That depends, someone might offer me a good price to resell it Mark... Ha ha ha!   I can get it wrapped in a really nice looking carbon fiber vynil if you want?
    • I ❤️ Matty I would like to thank Matty for going out his way in securing me a OEM NC detachable hard top for the NC Matty, your worth your weight in gold, and I cannot say how much I really appreciate your outstanding help I'll get it colour matched once I pick it up sometime in Dec-Jan 😁
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
