Hey guys, so in the middle of pulling apart my R33 gearbox.
It was noisy in first and second gear, third and forth noise pretty much goes away.
I’m up to pulling speedo drive sleeve off, but have to modify my puller set to fit, so it’s not fully pulled down yet.
The question I have for now, the input shaft bearing and the bigger bearing in the centre plate are rubber sealed bearings.
Now, from all the googling I’ve done, I’ve not come across any pics of sealed bearings.
I would have thought the bearings need to be open to ensure adequate lubrication. I mean, the factory Nissan bearing is open...
The input bearing feels ok by hand, keen to see what the one in the center plate feels like.
Any gearbox guru’s have any thoughts on the use of sealed bearings?
cheers
https://www.sau.com.au/forums/topic/481738-r33-gtst-gearbox-questions/
  • 3 weeks later...
  • 3 weeks later...
Bit late to reply, But yeah, the CBC kit I got came with the sealed bearings, on which I've removed the seals.
Just got it back together last night, hope to have it back in the car tomorrow. Pretty happy with the CBC kit, even came with 1st gear bush (which looked average on mine, burred on the edge where it looks like they've used an ill fitting pipe to drive it on). Someone has had this apart before and did a average job putting it back together.
The needle bearings on 1st and 2nd gear felt terrible as I was pulling it down, and popped the seal off the (old) bearing in the center plate and there was alot of black deposit, and the oil in there was much darker than the oil drained from the Gbox.
Anyway, will see if the gbox noise has gone soon enough!
  • Like 1
4 hours ago, hardsteppa said:
got to say, they are a fairly noisy box IMO . Still hear alot of operating noise from mine even after the full rebuild, but have come to love it 😛
Couldn't agree more. After going from a 22 year old box to a brand new one, it wasn't quieter at all to the ear.
Yes that's right, wasn't (past tense). Said new box went to gearbox heaven prematurely.
Hey guys, feel free to add any info to the thread if you feel its relevant, thats the best part about forums.
So, updating, as the box is back in the car, and to give the thread some closure.
Much anticipation I started car, and slowly released clutch, aaaand the noise is still there. Bugger. Probably a bit better, but hasn't "fixed" the noise.
So ultimately its got to be the gearset.
I also put a new syncro in 2nd gear, and the shift into second feels better, so along with the experience of actually rebuilding a box, it wasn't a complete waste of time (pretty close though, haha).
Plan from here is to keep driving/drifting with this box until it lets go, then probably buy new. I don't think "low km second hand" boxes exist anymore. And I'm not making the power where I think a gearset is warranted.
Thanks for the advice/help guys
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
    • Hey everyone! Im so grateful to be apart of this community and ill do my best to be apart of this. Firstly, i'm not disclosing my real name due to in real life circumstances surrounding my privacy and public image (sorry lol) Secondly, The only thing personal I am willing to share is that I'm from Sydney and a descendant of one of Sydneys largest mortgage firms. I got gifted my first ever car, a 2022 Porsche Cayenne and I love it to death. Ive been driving it for about 5 or 6 months now and honestly Im so grateful for my parents for gifting me this vehicle. However recently I've been working my ass off to afford my second car (which I need help deciding soooooo community help me out please?). Once decided, im planning to try modify it myself. Recent I've been thinking about getting a Skyline, particularly a 25GT or GT-V, yes I know overrated as hell, but I'm also considering a Chaser which I recently came to love. However my dream is to one day own a 180SX (So hard to find clean versions and im not really into importing).  Lastly before I send this off, I want to apologize if I sound tacky or pretentious. I try not to and want to genuinely learn from everyone and anyone. (Im no expert in this area) Thanks for reading!
    • I've got three stashed away but it's starting to get silly with the prices
