hey guys i am heading to the machine shop with my motor i bought to build for 800hp tomorow. So i figured id finish the tear down real quick as i already have the head off. the front left axle boot was still in the front diff so i figured id start there. grabbed my special tool i made to hit it out and 3 wacks later it popped out as it should. i was greeted with a bunch of red fluid pouring out.... i was really expecting to see a normal colour gear oil come out and when i saw what i swear is atf i almost shit myself. the diff gears etc look fine. my question is has anyone ever seen a red gear oil before? i pulled the filler plug and sure enough its full of red what i think is atf.  the only gear oil i ever saw that was a different colour before was that shitty redline fluid that is blueish. anyway any input would help. will the diff be damaged if it was ran with atf, and hgas anyone ever seen red gear oil. those are the questions im concerned about.
https://www.sau.com.au/forums/topic/481745-atf-in-my-rb26-front-diff/
It smells like gear oil deadly but that could just be from being in there for so long in now smells like gear oil....I dunno everything seems fine tho....
On 03/01/2021 at 3:00 PM, GTSBoy said:
ATF is thin and runny. That looks quite heavy.
hey mate, i poured both atf and the fluid coming out of my diff into 2 different cups. as i slowly poured them out into the bin you could see the fluid from the diff was draining much slower so proably gear oil and yeah definitly smells like gear oil. as stated probably a lsd fluid...i know my front diff is stock i think it is still acceptable for lsd fluid to be in a non lsd diff correct. i will switch it to my desired fluid with my quaiffe just comfirming if this is true about the lsd fluid in non lsd diff.
On 03/01/2021 at 2:11 PM, r32-25t said:
If it smells like gear oil then it’s gear oil, most lsd oils are coloured
thank mate definitely gear oil then
thanks mate, keep in touch im gunna have a bunch of single turbo swap stuff going on in the next couple weeks. probably have some more questions along the way. gunna use my stock motor thats in the car to plumb everything up and then when the built motor is done i will swap it in and crank boost way up. cheers thanks again your help is always well helpful not a bunch of bullshit and false info.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
