maintenance before start up (car hasn't been driven in 12 months)
haven't driven my car for a year
pretty much impossible to get it towed (stored in an underground car park) I'll have to check its actually still there.
recommendations on servicing so i can get it running safely so i can get it to a mechanic?
i couldnt be bothered changing all fluids etc. Mechanic is a 5 min drive away.
Edited by defari
Fuel will be sh!t....may not even fire on the fuel you have in it, it depends on the motor.  I have had it not start [replaced fuel with fresh stuff and it worked fine] but have also had another motor start fine after sitting for 18 months.  So cross your fingers and see?
7 minutes ago, defari said:
Battery is long dead.
Going to drain fuel tank + put in some fresh fuel.
Is it worth doing oil / rad fluid change if its going to a mechanic only a few km's away?
Car is a 1999 sti wrx.
If the mec is 10 minutes away I would just put some engine and radiator flush through it for the drive to the mec, then get them to change every oil and fluid
I would pull the plugs for the first turnover to build some oil pressure, after sitting around for 12 months there isn't going to be much oil in it, apart from the sump.
Wait, it a boxer, LOL, bugger pulling the plugs, does it have the "flooded" engine thingie where if you hold your foot flat on the accelerator it doesn't start, if so do that a few times.
I love that advice as it is either good and prudent to allow oil pressure to build or it will start and rev its guts out!
LOL, yeah, it's a hit or miss kinda thing
flooded engine thingie? I wouldnt know.
It is a function that most EFI cars have
Both my 2015 STI and my 2017 86 had it, from googling Subaru has had this thingie for years
My 2002 Dunnydoore has it
Basically you hold the pedal down, then try and crank the car, the FI system recognises WOT with the car off, this engages the "flooded engine" mode, and shuts off the injectors while it cranks over
After a oil change I usually give it 2 or 3 hits for about 5 seconds each, with the plugs in it doesn't really turn over that fast, but with the plugs removed it turns over much much quicker
Be aware that if you crank it for more than 10 seconds the car may start, but after 10 seconds of cranking the oil should be feed around all the oily bits
ahh ok i see.
like you mentioned, i was concerned about the oil situation.
cheers for the info.
Edited by defari
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
