Man it must be amazing to see a brand spanking new paint job on a GT-R!!  Would be the final piece of the puzzle to make it feel like a new car all over again!
Your dad is a legend for being into them and you for helping him!  Great to see.
Yeah us ex Shep boys going hard now ! Old man was like fk it, give me your old R33 GTR wheels so it'll hook up....
Came back with fresh Hankook RS4 !
  • Like 1
Did I know you were ex Shepp?? I can't remember knowing that! 🤣
You're a better at Sheppresent than me, you get shit done!
The race continues to be ready for tuning, putting the car back together. Here is a bit of a look at the brand new replacement outer sills that have been replaced on both sides. Just about to put the freshly painted sideskirts on after fitting new front inner guardliners and new series 2 rear mudguards - I have a mountain of genuine Nissan clips and bolts for the jobs ahead. Doors were also removed as part of the paint job and realigned. With new strikers they shut perfectly now, as they were shocking before. As you can see I'm a bit shit at taking photos though
  • Like 5
On 04/08/2021 at 2:56 PM, Dose Pipe Sutututu said:
GT-R badge missing, you want a R33 GT-R one?
Took it off the boot I purchase for my GTS-t shit box because noway I've having GT-R badges on a shit box GTS-t lol
Nah it's on there, zoom in
On 04/08/2021 at 8:08 PM, Dose Pipe Sutututu said:
Shit.....
Yeah, what a polarising couple of days. We were doing all the 98 baseline tuning and then had troubles going to 8000rpm redline. We'd get up to about 10psi boost and fuel pressure was going from 50psi and then falling off a cliff repeatedly with stable manifold pressure. Thought it was shitty pump relays, bypassed them. Thought it was SSR / PWM problems - also bypassed it, so this time it's literally direct to battery feed for pump power. With all pump control ruled out it appeared to be faulty fuel pump, as pump terminals were at 13v during pressure fall off during dyno runs.
Fuel pump was a Walbro 525lph F0000285, done 2500km. It was mostly highway driving with 1500km of that done to get to Adelaide no problems, so we could only conclude that the pump must be faulty. Cue Simon getting straight onto a local supplier to get a new one delivered so we could change it ASAP. I had the pump out and swapped it in myself while still on the hub dyno fairly quickly - at a cost of cracking my head open in the process quite severely on the stupid boot catch with blood pissing out of my head everywhere.
Should have probably gone to get stitches but fk it, we really needed to push on. Get back into it with the new pump and shit started doing the same thing ?! Perplexed at the pressure problems we started clutching at straws,  so we pulled the pre rail 40 micron Speedflow 602 AN8 fuel filter to inspect. To our surprise it was almost completely blocked - couldn't even blow through it. We pulled it apart and it was really bad, like a fine silt. We had the tank completely drained, empty, dry and clean on Saturday, so we knew it's not from a dirty tank. Filter was 2500km new and checked after 1000km engine run in, so only explanation is we've picked up bad fuel at one of the fuel stops to Adelaide on the drive down. All fuel on drive down was 98, but with outback fuel stops like Erldunda, Marla, Coober Pedy, Glendambo and Port Augusta I bet one of them has had some bad fuel contamination.
After replacing the fuel filter element we got into it again and full fuel pressure appeared to be restored, so we could finally start loading it up. Did a full run up to 8000rpm to check gate base pressure which was 15psi so it all looked good to go. During about the 4th power run still on 15psi boost we noticed the oil pressure at about 4000 - 5000rpm suddenly dropped sharply about 20psi, so the run was aborted. Returning to idle at 1000rpm the oil pressure had gone to about 15psi. Oil pressure at idle was around 35psi before that, so the decision was made to not progress any further.
  • Like 1
  • Sad 2
I hope so, but I will expect no less than damaged crank and main bearings. Just about to go back down there, take front lip off and organise the white 32 to be taken back to the NT via car carrier.
Before I do that I'm going to take the blue 32 for a quick spin, put that on the trailer and drive it back tomorrow.
White 32 - mission aborted 👎
  • Sad 1
Yeah that sucks, not much you can do to guarantee clean fuel from stops that probably don't sell a tank a year though :(
You should be able to get an oil analysis done pretty quickly before deciding to pull the engine, at least you will know if there is bearing material there - I take it there is no knock yet since you didn't mention
A fuel problem might hurt the big ends if the run wasn't stopped when detonation was detected, but it shouldn't hurt the main bearings unless there is a lot of crap in the oil
Engine will definitely be coming straight out and disassembled for a post mortem. We've been discussing this and I think the main bearing oil clearances might have been set a bit tight by the old man. He showed me that he'd set it at around 0.025mm, which I believe is on the tight side. I expect the bad fuel contamination has gotten into the oil and probably starved a main.
I'm prepared for the crank to be stuffed, just hopefully not the rods. Pistons and rings should be ok. Funnily enough, Simon started it cold briefly the next day just to move it and it had 125psi oil pressure at idle.
Maybe some sort of main bearing issue (not spinning because you would hear it) but could be clearances, or maybe something simple but critical like an oil gallery plug missing like that nasty one where the filter housing attaches that causes oil to bypass rather than circulate, or o-ring on the oil pickup missing etc
I'd still start with checking on a mechanical gauge and doing an oil analysis before pulling the engine, and with stuff like this best to ask the machine shop's opinion not the internet because it is expensive to be wrong.
I've just pulled my motor after about 5 (short!) seasons because it was idling around 30psi and only giving 50-70 psi at full noise, standard bottom end with nitto pump running 20w50. I would not be comfortable with 15 at idle.
Yeah dropping from 35 down to 15psi at idle means something has happened.  As mentioned above I think the old man might have set his oil clearances too tight and it picked up a bearing on load. Car is getting picked up and shipped back Monday, so once it arrives engine will come straight out and bottom end disassembled.
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
