Hey Guys,
So recently I put a post up thinking I had finally solved my speed sensor issue and got the right speed sensor what my RB25 gearbox. Turns out I'm a flipping numpty and the new sensor doesn't fit and I had the right sensor all along. I know I have the right sensor for the gearbox, I know there's no problem with the sensor itself (it's sending a clean signal to the dash when manually turned outside of the box).
Problem is as soon as I put the sensor in the box and turn the engine I get no signal at all. Has anyone got ideas what it could be? Like could it be the worm gear put in back to front etc? Visual inspection of the worm gear seems fine and it's rotating when I spin the wheels with my feet and look in the gearbox at the same time.... Stumped.
https://www.sau.com.au/forums/topic/481774-rb25det-gearbox-worm-gear/
10 hours ago, GTSBoy said:
that maybe you get no rotation.
Or is the rotation in the correct direction. Do you have a mixed set, note below, the gtr33 and KA auto rotate in opposite direction to the others. Just a thought. GTSBoy knows more than I, about this subject.
I need red gear pinion speed sensor/VSS help (Z32 style, RB trans in S13) -  Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum
Edited by Rusty Nuts
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
