pretty straight forward i haven't heard a bad thing about this product yet so really I'm looking for anyone that thinks wpc treating my rb26 or any engine build is a waste of time...from what i see which is only online content it is a god saver for metal and makes engines last at least 50 percent longer...looking for only the top dogs to put up some info here nothing shady/no newbs please!
https://www.sau.com.au/forums/topic/481776-wpc-treatmeant-for-my-rb26-build/
From what I recall, This was developed by a couple of companies in the Fuji Heavy Industries Group. Its a refinement of shot peening, using smaller projectiles(media) at much higher speeds. Its been around for years and highly regarded particularly in Trumpland. Only ever heard one naysayer, who said " but its a sacrificial process"  Where its more like a microscopic forging and heat treatment, with rapid heat rise and cool at the impact points.
yeah i researched the process pretty intense. i think its well worth it im gunna give it a shot. about 1000 bucks to do the entire rotating assembly plus shipping. seems to me that sa great way to save bearings, etc from the rb's crank walk issues. ive got a prp brace and with, the wpc i hope to pull my new engine down after 2 years and be able to confirm the results.
nismo bearings. im still trying to figure out which coating is on the bearings cause they may not accept the the wpc properly. the new king bearings have a coating on them that are pretty good but im staying, my engine was line bored and crank machined a bit so will have to go one size over Nismo bearing on the rods and mains. but yeah wpc the whole rest of the engine pretty much. will post pics and lots of success or not success videos. the process was much cheaper than i thought. its simple less friction more power more smiles.
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
