The colour code is in the middle of the vin plate.  What colour is it in real life?
KH2 - Gun Grey Metallic
KG1 - Jet Silver Metallic
KL0 - Spark Silver Metallic
TH1 - Dark Blue Pearl
AH3 - Red Pearl Metallic
732 - Black Pearl Metallic
326 - Crystal White
BL0 - Greyish Blue Pearl (special order)
In other series it means that the car was removed from the production line for another manufacturer to build like Autech etc. Not sure if that applies to your car.
Generally in R32 the engine bay should be a duller version of the original exterior colour, so a red metallic car would have a dark red engine bay
On 1/15/2021 at 10:26 AM, sin- said:
Can you post or PM me a photo of the VIN plate?
2 hours ago, BK said:
Where is your actual blue factory build plate. Not the SEVS plate, not the import issued VIN plate - the build plate.
Something stinks....
This was my first ever skyline and did not know what to look for.
It does not have a blue plate like the R33 GTST I have.
I thought because it had the ADR Plate, that it was fine.
Missing build plate is a massive warning sign !
Does your car have any of the things listed in the specs ? HCR32-292195 is definitely supposed to be AH3 red pearl. It is also supposed to have a sunroof. Does it ?
If you had a build plate it would tell you that information, as that chassis code is a series 2 also.
3 hours ago, Francois said:
mine is one of them
No, it's not. It clearly says what it says. Your model code is KRCR32RKRCR32RGASLA and there are 205 cars in that spec, or at least 205 of that spec for whatever car actually is HCR32-292195, because it's not your chassis.
Your Australian VIN issue not being obtainable is another story. Use vincheck, pay $9.90 and see what it says as that information is from the Australian Federal government
Perhaps see if you can get a copy of the import approval from DOTARS for that VIN, it may have further information. De-registration or auction papers from Japan may also be available for HCR32-292195.
But given the factory VIN stamp is not on the firewall HCR32-xxxxxx and there is no Japanese blue build plate, unfortunately it looks no good.
You could also contact Lena Skyline / Lena Engineering / Nam T Le to see what records they have, but presumably the original import was correct and the tags were changed in Australia after compliance.
Duncan it's hard to see but zoom in - the chassis code actually is stamped in the firewall above the silver riveted VIN plate tag, so the firewall is at least from said chassis number.
As the firewall is a two piece construction, I suspect the entire front firewall section at a minimum has been replaced.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
