Are the re-appearance of the famous Nismo key blanks genuine? or copies?
I've noticed recently a whole bunch of the famous Nismo metal key blanks appearing on eBay and also on the Kudos website...
http://www.kudosmotorsports.com/catalog/blank-nismo-style-nissan-a31c33r32r33rnn14s13s14wc34z31z32-p-2400.html
These keys in years past used to sell for several hundred dollars USD, but are going for $70-80 now 🤔
Does anyone know if these are genuine? Good reproductions? Old stock that someone has discovered? Or has Nismo has started making them again?
Hoping someone might know :)
Cheers
Edited by KrazyKong
  • Like 1
If Kudos Motorsport has them I'd think they'd be genuine Nismo - they don't sell crap or knockoffs. Neither does CJmotor on Ebay. What is confusing is the price at $66 from Kudos and $79 from Jacky at CJmotor. Very strange, as it appears to be genuine as the original "Nismo Design Key" is infact part number KEY01-RN008.
For comparison, the definitely known to be genuine BCNR33 GTR keys are $99, but that R33 GTR key is now part of the Nismo Heritage program, part KEY00-RHR30 to replace existing genuine Nissan part KEY00-00185 which is why they've gone from about $50 up to $99.
Check RHDjapan. If it's aftermarket and available, they 99% of the time have it listed on their site. This Nismo logo key is not listed on RHDjapan and is definitely not listed in the 2020 Nismo catalogue.
I think a call to Andrew at Kudos or Jacky at CJmotor is the only way you'll get an explanation
  • Like 2
On 16/01/2021 at 12:50 PM, Butters said:
Amm ... it tells you in the advert, "Style" is the code for china copy ........   "Nismo Style Key (Blank) for Nissan"
I'm inclined to agree here
I contacted Andrew at Kudos and he confirmed these are just good quality reproductions. I guess the question then is, can a difference be seen between a genuine and a reproduction? I might have to purchase one of the reproductions and then compare it with a genuine blank that I have.
Edited by KrazyKong
I bought one. Been really needing a spare key.
They are heavy, likely a low grade steel and coated. I am the worst at metals though so don't trust my judgement.
I do expect the coating will degrade over time otherwise seems very solid.
Will post a pic once i get it cut.
I guess the question is who gives a shit ? Key that turns car on is enough really. The genuine GTR keys also degrade over time too.
  • Like 1
  • 3 months later...
  • 3 months later...
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
