hello, we recently bought an r33 with a set of tein coilovers, not too sure which model but they are height and damper adjustable. they have green springs and the shocks are gold with green ends.
we have managed to adjust the height to the spec we want it. but how can we soften the damper amount? the ride is so bumpy on the littlest nook and cranny and its getting a bit annoying.
what do we need to move or adjust?
or maybe is it possible to just get softer springs?
can anybody please help us out? and let us know what we should do?
thank you in advance.
regards,
kuro :)
https://www.sau.com.au/forums/topic/4818-how-to-adjust-tein-suspension/
Unfortunately most of the Japanese sports suspension (Tein, Tanabe, JIC, etc) is going to be rock-hard. There should be an adjuster nut in the centre of the top of the shock absorber, I'm not sure which direction is for the softer settings but common sense tells me anti-clockwise.
Softer springs may help but I think most of the ride harshness is from the shock absorber. Custom springs for those large shocks is also going to cost a fair bit of money.
You can actually download PDF manuals for Tein shocks. There are some manuals here:
http://www.tein.com/ti/tnissan.html
but not for the R33 GTs-T but the shocks should all work fairly similarly.
I think you will also find that raising and lowering the ride height changes the spring rate. So an incorrectly adjusted ride height could cause issues.
I have a set of Tein's on my Cefiro and they rock hard. It's the price you pay for having coilovers. Whiteline website has a good article on coilovers vs "normal" shocks. It lists pro's and con's. Worth a read. The article is located here:
http://www.whiteline.com.au/articles/coilo...r_H4s_2000a.htm
Hope this helps.
  • Like 1
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
