Exchanging the japanese radio/navi for an english language one - what to use
Guys, basically I got one question.
So I still have the double din radio/navi in my car and besides that I only got unusable japanese frequencies in the radio, it only reads CDs and is 99% in japanese - it is working fine ^^
It also has a rear port ( cinch ) for the rear camera, which automatically starts and gets projected on the screen as soon as I hit the reverse gear - do many radios have such a port for a camera and will the be activated too directly or is it a question if additional signal cables from the gear to the radio to let it know, when to project the rear view?
Sorry if this isnt good english but as I said before, Im german. :D
Thank you guys ❤️
BTW: The radio is a clarion addzest something road explorer 3.0 HDD
Just about any double DIN car stereo with a big LCD screen would have a video input for reversing cameras.
I don't know about how the signal and screen are activated in your car. AFAIK R33s didn't come with this stuff. Are you talking about some later V series or Stagea? Actually, I don't even know how the camera and screen are activated in those later cars either. But it is quite possible that there is a "reverse" wire that comes from the gear shifter reverse switch or from the BCM that would tell the stereo to switch over to reverse camera mode. Or, it could be that the stereo automatically does so whenever the camera signal goes live.
Ah I see, but you couldnt say that they all got this input point in form of a cinch plug I suppose?
Yeye, its my R33 Gtst. Looks like I would have have to take the radio out and have a look where all wires are going or if one directs to the gearbox or something. Sigh ^^
It has to be one of two no?
Get the camera power as soon as you hit reverse and the screen recognizes that and switches OR
tell the screen when it is reverse and let it switch to the always powered cam
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
    • Are you talking about the oil squirters? There is only one place for them to go. Yes, you have to drill the holes. Yes you have to obtain the correct oil squirters (I presume there is some sort of aftermarket option available, because original turbo ones are going to be a diminishing resource).
